My New Project
Old Feb 16, 2013 | 01:27 PM
  #151
Robert AMG's Avatar
Cls63 & C32
Originally Posted by macbryanie
How is this monster going?
Wouldnt a 32 supercharger have been easier fit on a 350 engine? (3.7).
My 32 engine is losing mojo (210 thousand kms): considering purchasing a 350 engine and modding with the 32 s/c. A world of pain or worth it?
A c32 engine rebuild and or replace is $6k+. The 350 engine is 2.5k. A similar project seems reasonable as opposed to rebuild/replace.
No much time for the car, but i was waiting new piston rings(they arrived yesterday) and i went with the w210 55amg piston which lower my Cr to 8.2,
next week i'll finish assembling the engine, i wraped the headers and installed dual nozzle meth:
as for the 350 engine you can fit it but you need 55amg na pistons to lower the compression, and you will not get any benefit cause you will loose boost with the same sc, i suggest to rebuilt the c32 engine with used parts and i have all parts if you need i can ship them to you.
Old Feb 16, 2013 | 04:20 PM
  #152
tw2's Avatar
tw2
You will lower boost but power should be the same since the same amount of air is going in. Torque will increase. A crank pulley to go with the smaller supercharger pulley you already have will bring boost back up. People run stacked setups on the stock 32 engine so the supercharger can I guess take the extra revs.
Old Feb 17, 2013 | 07:13 PM
  #153
macbryanie's Avatar
Porsche 2004 911
PM sent
Old Feb 17, 2013 | 07:17 PM
  #154
macbryanie's Avatar
Porsche 2004 911
Sorry for the thread hijack:
Cheers for the advise tw2: greatly appreciated.
Will go the rebuild and be content with the output of the 32. Only one way to make the next step and I am a couple of years off that.
Alas...Robert’s project is absolutely brilliant and tempting to emulate.
Old Feb 18, 2013 | 12:59 AM
  #155
tw2's Avatar
tw2
I was very tempted also, then again spinning the wheels in every gear might have its drawbacks also
Old Feb 18, 2013 | 03:00 AM
  #156
rkvucynq24's Avatar
jeep
Nice write-up, thanks!
Old Feb 20, 2013 | 04:18 AM
  #157
macbryanie's Avatar
Porsche 2004 911
What meth kit did you use?
Old Feb 21, 2013 | 02:59 PM
  #158
Robert AMG's Avatar
Cls63 & C32
Devilsown stg 1 upgraded solenoid, dual nozzle.
Old Mar 17, 2013 | 05:31 PM
  #159
Robert AMG's Avatar
Cls63 & C32
We started the car on Saturday after the engine rebuilt, everything went good, engine run smooth, we installed also the 82mm tb right before the air filter, took out the egr valves and secondary air injection.
Old Mar 17, 2013 | 10:44 PM
  #160
macbryanie's Avatar
Porsche 2004 911
Attachment 255403
What a monster that engine has become.
Old Mar 18, 2013 | 09:42 PM
  #161
C_DirtyTwo's Avatar
a land yacht.
looks beastly. We need vids!!! Why did you position the intake there? Unless there is some sort of cutout on the hood or in the fender well how will it get cold air?
Looks like theres plenty of room to wrap it around up front like a single needswings intake
Old Mar 20, 2013 | 04:55 PM
  #162
Robert AMG's Avatar
Cls63 & C32
There is no place in the fender to put the filter even before the radiators there is no place, i have a large 3.5" filter and because of that needswings do no make single intake for C32's, in post 128 i have a picture where i direct a pipe from fender to where i placed the filter i'll be putting it to get cold air, also it takes cold air from rear hood fender plus i'll wrap it from the engine side.
i am doing some miles on the engine before going WOT, next week i'll post video's.
Old Apr 11, 2013 | 07:59 AM
  #163
macbryanie's Avatar
Porsche 2004 911
vids?
Old Apr 11, 2013 | 12:07 PM
  #164
TruTaing's Avatar
Moderator Alumni
w203 m112
Holy crap! This just keeps getting better and better.
I am imagining the SC sucking air straight out of the cabin and the SC whine to be 10x louder in that position.
Could you post more pictures of the front of the motor - Im curious to see how you got the m113k SC pulley to line up with the c32 crank.
Also - I hope when you're done you do a massive parts list drop on the first page of this thread!
Keep up the great work and get those vids up!
Old Jul 21, 2013 | 09:48 PM
  #165
Biscuit's Avatar
'03 C32, '08 ML63
Any updates?
Old Jul 21, 2013 | 09:51 PM
  #166
ChiCho55AMG's Avatar
W209 CLK55 AMG Kompressor, ATV BRP 800 CAN-AM
Originally Posted by Biscuit
Any updates?
VERY SOON
Old Jul 22, 2013 | 09:45 AM
  #167
macbryanie's Avatar
Porsche 2004 911
Originally Posted by ChiCho55AMG
VERY SOON
Sweet...
Old Jul 22, 2013 | 12:12 PM
  #168
Robert AMG's Avatar
Cls63 & C32
Well guys i didn't update this thread from long time cause i am still fighting a lot of problems after i rebuilt the engine from like 4 months,
after i finished it the car was loosing boost up top instead of going up to 1.5 bars like before now it goes to 1.3 then down to 1.2 bars, and it made only 485-490 hp crank so like 60/70 hp down plus sometimes the boost drop like a slippage to below 1 bar.
i have changed everything and still problem not solved, i did compression tests, boost leak tests, changed to another 82 tb, bought a second supercharged and cut the rear runners, changed all gaskets, made a clutchless sc pulley and ...... still no power like before
today i installed the stock 74mm tb, tomorow i'll go to the dyno and we'll see, if not solved, don't know what to do! maybe an IC leak test.
i am suspecting that maybe before we installed the timing chain one tooth advanced and it upped the hp then pistons were failed.
before i was getting like 160/165 psi cranking CR, now after the rebuilt i am getting between 125/135 psi.
after all i'll go with bigger pulleys.
i am really tired.
Old Jul 25, 2013 | 04:47 PM
  #169
Robert AMG's Avatar
Cls63 & C32
Update: i discovered yesterday that the dyno numbers are very low and different from last year, the operator didn't told anything about the nb that they were updated and are lower then last year, i suspected this, and send today my brother to this same dyno, last year his car clk55 made 374 crank hp, today it made only 331, so the problem is in the dyno, the car has no problem and the boost is decreasing on the dyno which is normal but on the road it doesn't and last year i wasn't looking on boost on the dyno.
plus my sc pulley is bad, i went now with clutchless pulley.
yes the car has no problems, i was working 4 months and payed more then 1500$ for nothing.
so now it's time for 180mm pulley, 750cc injectors, meth and dyno tune.
guys don't trust dyno's, only if tested in the same day.
Old Jul 25, 2013 | 05:24 PM
  #170
raf12690's Avatar
c32 amg
Dang sorry to hear you wasted some of your time! Good news though if you ask me. I'm sure some of the things you inspected/replaced are better off for it at least. Looking forward to results!
Old Jul 26, 2013 | 03:08 AM
  #171
macbryanie's Avatar
Porsche 2004 911
Awesome, so glad that you have identified the issue and especially that it wasn't your car.
Old Jul 26, 2013 | 05:37 AM
  #172
betrezra's Avatar
C63 507 AMG DA Car #19
Great lesson here for the Internet dyno lot. Great build.
Old Jul 26, 2013 | 12:26 PM
  #173
TruTaing's Avatar
Moderator Alumni
w203 m112
Doh! That sucks. Great lesson for the rest of us though. Someone should jump on your second modded supercharger :x
Old Jul 27, 2013 | 05:03 PM
  #174
Robert AMG's Avatar
Cls63 & C32
last dynos before going bigger pulleys:
Old Nov 1, 2013 | 08:56 PM
  #175
Billy22Bob's Avatar
R170 99SLK230 + SLK32
Update Please
Update Please Robert
