C55 Service Visit
C55 Service Visit
I finally went to the MB dealership to get the seat heaters replaced under my 3rd party warranty, and need some other work done after dealer inspection. So I'm looking for the most cost-effective way to address certain issues. Also, which fixes are urgent, and which can I wait on? Just trying not to get taken for a ride, thanks!
1) I'm buying Akebono ceramic brake pads for the front (need replacing). Can I get any car shop to put these on even outside of an MB dealer? I'm not mechanically inclined at all! Cost?
2) I'm looking to just buy the OEM air filters to replace a dirty one (Mann filters right?) Same as above, can some shop easily replace this? Cost?
3) Brake Fluid Change - Dealer says the fluid is greenish colored and needs to be changed. Cost?
4) Transmission Flush/Service - Never been done. Cost?
Any shop should be able to do the brake pads. It's pretty easy to do yourself if you have the time and some simple tools. I bought akebono euro pads for 80 dollars I believe online a while ago and have zero brake dust because of them.
CLS, SLK, ETC
2. Cheap. Get filters from online source. You should try this by yourself. They are very easy to change and it should only take 15-20 mins. Do search for direction.
3. Again, price can be vary from dealer to dealer but do expect to pay $150-250.
4. Same here.. Expect $300 +
All of your work can be done by an independent mercedes shop / tuning shop. They charge less and may do a better job.
Good luck..
P.s: Don't bother fixing up the seat heater. They will fail again...and again...But if it's covered by your warranty, why not..
1 Post
1996 S420 2006 C55AMG 2002Mustang GT
my benz dealer charged me 270 for my tranny flush, and me personally if u got them under there have em flush your diff too my dealer charged me 89 for it.
My indy MB master tech charged me around $100 for a tranny flush.
A far cry from the $300-$500 quotes I got from several dealerships.![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
Some dealerships also suggested changing the conductor plug and filter when doing a flush. Has anybody gone this route?
My local dealer quoted $850 for the transmission flush which is about US$600-700. I decided to never do it since so many high mileage transmissions seem to fail right after it is done.
I am at approximately 90,000 miles. The way I see it is they are supposed to be sealed from factory, there is no mention of transmission fluid anywhere in the service schedule.
It seems, a high proportion of people who flush the fluid on high mileage transmissions that have never had a change before encounter problems. Like most things with mercedes, the problem usually ends up being a few thousand dollars and many brand new difficult to install parts.
The consequences for doing the fluid change can end up being needing a rebuilt transmission in some cases. Not doing the change will most likely not cause any real problems for a long time in which it will be a rebuilt transmission anyway.
Other issues are the fact it is very difficult to get all the fluid out of all the components anyway, they can be hard to seal afterwards and getting the fluid levels correct is difficult.
I fully agree a new car should have the fluid changed every 30-40,000 miles but I think it can be asking for trouble on an old car that has not been perfectly maintained. This is just my opinion based on what I have read and understand, I am very open to others experiences and evidence to change my mind.
1 Post
well from what ive researched in the past mercedes changed their stance on the sealed for life transmissions because it just didnt work to what they had hoped, myself i flushed my tranny at 89K and have not had issues, that being said i know what your saying about tinkering with old automatics that were never flushed and by flushing them dislodged metal shavings or clogging up a channel. i mean i took the risk but due to my profession i see machinery and moving parts and what happens when regular maintenece breaks down and what happens to the machinery. that and im a freak on doing maintnence. however seeing what the dealer wants to charge you i dont blame you for not doing the service. so its kind of a damned if you do damned if you dont with an old tranny that hasnt been regulary maintained i guess i wish you the best but me personally it would kill me having denatured oil not properly lubricating and cooling a transmission.
2005 C55 AMG
The filter is $16 and the pan gasket is only another $15 - and those are both retail dealer prices. Your indy may charge even less. Aside from changing the filter, dropping the pan allows the tech to clean the pan magnet.
I've had the conductor plug changed. It was inexpensive at the dealer. Mine wasn't leaking. As long as they wereworking on it, I told them to go ahead and install the upgraded part.
Is there anything to gain from dropping the pan, replacing the filter, cleaning the magnet, new gasket and refilling the fluid?
This would mean the torque converter and coolant lines are still filled with old fluid but I think this is how most of the old debris gets disturbed?
2016 Chevrolet SS, 2006 Cadillac STS-V
$100 is awfully cheap since the fluid is $15 qt. and probably another $40 for the filter, gasket, drain plug seal, and dipstick cap retainer. You just barely covered the parts, so either they really like you or they used crappy parts and one-size-fits-all transmission fluid.
I can do that. My only question is how do I know how much fluid to put back in? Is that what the dipstick people buy is for? I presume this comes from the dealer? And it goes down the tube next to the firewall with the red plastic clip on it?
Yes, that is what the dipstick is for. You can get one from any dealer or any of the online factory Benz parts sources. You will need to buy a replacement clip after you take the cap off the dipstick tube because you have to break that clip. The part number is in the pictures of that thread the OP posted.
I'm sure if I mention the shop's name, you'll know it. They sometimes even post here and some other members use them as well. They also definitely dropped the pan, changed the gaskets and used OEM parts.
It's just the conductor plug that wasn't change. Upon inspection, they said it doesn't really need to be replaced at that time and left it up to me if I wanted to anyway. I decided not to back then.
Come to think of it, I had several other things done on the car during that time so maybe they gave me some sort of discount.
Porsche 2004 911
Tw2: autohauz is international if the dealer slaps a heavy fee: http://www.autohausaz.com/search/pro...r=140589152100
https://mbworld.org/forums/c32-amg-c...-dipstick.html
