*terrible thread by pointman: help! I got too many pounds!
Old Jun 8, 2012 | 09:19 PM
pointman's Avatar
a car that can't do the throttle reset.
and now that I got all of your attention since you are all concerned with my health and my elevated BMI... no, this isn't about my weight. its about tire pressure! Door jamb suggestions 32 front, 36 rear when cold. I follow that and I get tires that wear more in the middles!
I did a good search like a good noob, but all I came up with is stuff like
"hey, I just got 22's on my C32. What pressure should I..."
"I am going drifting tomorrow against some ricers, what is my best bet pressure..."
"I just bought a four owner C32 and I ran 19 psi in my accord, what should I rock in my new AMG?"
Help!
Old Jun 8, 2012 | 09:36 PM
MIKESV8's Avatar
Aston Martin V8 Vantage
i run 40PSI on all 4 and they wear properly like the AMGs do. then again i have nitrogen in my tires so the PSI hardly changes.
Old Jun 8, 2012 | 09:49 PM
loudandheard's Avatar
C32/C55 AMG
I run 35-40 psi depending on the tire, but on 18" rims.
Old Jun 9, 2012 | 12:02 AM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
Same. Rears evaporate every 15k, fronts about 30k even though I drive like my mother.
Old Jun 9, 2012 | 12:59 AM
MIKESV8's Avatar
interesting piece of info. thanks every year or so then.
Old Jun 9, 2012 | 02:39 AM
tw2's Avatar
tw2
I run 40psi all around, so far the wear looks fine.
Old Jun 9, 2012 | 07:14 AM
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
I run about 30PSI (for air, about 33PSI for nitrogen) all the way around. 36PSI is way to high (as you know since you're wearing out the middle of your tires). I wore out the middle of my Pirelli's and I changed when I replaced the rears with the first set of Michelin's and they looked good and my Pilot Super Sports are evenly worn front and rear.
Old Jun 9, 2012 | 02:56 PM
pointman's Avatar
Thanks RS. I keep my psi strictly where its suppose to be.. and apparently 36 ain't it. But everyone else in this thread is saying 40! wtf!?!
Old Jun 9, 2012 | 03:41 PM
lkfoster's Avatar
Recommeded pressures on my '06 are 33/37 so 40 isn't that much of a stretch. Tire wear across the tread has been even on the last four sets of rears.
Same pressure up front takes out some of the under steer that manufacturers dial in as it's "safer" to hit a tree with your front end instead of the rear end.
Old Jun 9, 2012 | 09:16 PM
91RS's Avatar
I'm not really sure why people run tire pressure that high. It'll wear out the centers for sure.
Old Jun 11, 2012 | 04:05 PM
blade08's Avatar
to the hoop!
Old Jun 11, 2012 | 04:50 PM
pointman's Avatar
Originally Posted by blade08
I already told you that in the thread title, noob. Next time just check for my name and you should know what you're getting yourself into.
Old Jun 11, 2012 | 05:24 PM
mikekuriger's Avatar
2010 C63
my tires wear out too fast with the recommended pressure, so I run 29 psi. everyone says , "oh no that's too low!" but I have 163,000 miles and get 30-40k out of a set of rear tires. more out of the fronts.
Old Jun 11, 2012 | 06:30 PM
firstshadow's Avatar
03 C32 AMG
I run 40psi in my tires and get even wear. Then again, I do take the corners hard so that might have evened it out
Running on the stock 17" rims with kumho ecsta asx tires.
Old Jun 11, 2012 | 08:50 PM
pointman's Avatar
Damn. At all four corners? Hows your mpg?
Old Jun 12, 2012 | 08:44 AM
aussie e55's Avatar
2009 C 63
Smile
i run 40 psi all round with a good alignment very even wear
Old Jun 12, 2012 | 10:18 AM
blade08's Avatar
to the hoop!
Haha, the "PRO" took it seriously.
Old Jun 12, 2012 | 04:09 PM
pointman's Avatar
Old Jun 13, 2012 | 12:14 PM
MarcusF's Avatar
2002 CLK430
Asking people what they run is a good start, but to determine the correct pressure for your car "I think" this is a better approach - http://www.marcusfitzhugh.com/CLK/DIY/tirepressure.html
