Buying 2003 c32 amg
Old Aug 13, 2012 | 01:22 PM
Pure's Avatar
c32 amg 2003
Buying 2003 c32 amg
I have test driven it and the car is fkin amazing.,.
what things should i look for when buying this car?
Old Aug 13, 2012 | 01:37 PM
W203Ramos's Avatar
'03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
4 tires and an engine..........how many miles and how much
Old Aug 13, 2012 | 01:42 PM
Pure's Avatar
c32 amg 2003
67000 kilmeters for around 18grand..
Old Aug 13, 2012 | 01:49 PM
W203Ramos's Avatar
as much as i'd like this car to be worth more, it is not.....I would offer him $15k since it only has about 41,000 mi. i think thats a fair offer. also ask him if the IC pump has been replaced and what type of radiator is on the car.
Old Aug 13, 2012 | 01:57 PM
Pure's Avatar
c32 amg 2003
i have been reading some of your other posts around the forum, you seem very intelligent with this car
Old Aug 13, 2012 | 02:02 PM
W203Ramos's Avatar
Thanks.....GL with your purchase, I had this car since new and have no regrets. oh and welcome to the forum.
John
Old Aug 13, 2012 | 02:15 PM
Pure's Avatar
c32 amg 2003
John
wait... so what kind of radiator am i looking for?
Old Aug 13, 2012 | 03:30 PM
Dasauto's Avatar
2003 C32
Do yourself a favor and get a good pre-purchase inspection by a qualified tech who knows AMG's. Purchased my own 2003 C32 a little over a year ago and it's a fantastic car but there are several things you need to check. First off.......maintenance records are key. These cars are $$$ to fix even if properly maintained. Make sure intercooler pump is working..........and have them pull one/both of the intakes to ensure the intercooler is not leaking (takes 15 mins max). You'll know immediately if it is, there will be brown/green gunk all over the inside of the intakes.
Most common failures are IC pump and IC failure. IC pump is cheap ($150) but Intercooler almost $1000 just for the part and they're known to fail starting around 50K miles. Ask me how I know.
Also make sure belt and all pulleys/bearings are good. Had a crank pulley fail, harmonic balancer went kaput. I was lucky as it was replaced before the belt flew off.
They also like to throw engine codes, especially vacuum (fuel tank vapors or faulty gas cap).
As was already said.......the radiator can be an issue for 02's and early 03's. They could leak causing trans fluid to get contaminated. Have a glycol test done on the trans fluid.
Lastly........I'll bet the bottom seat heaters are broken (your butt, not back). If not they will be soon. Almost everyone I know who has a C32 has this issue and even when replaced they seem to go again.
You'll have peace of mind by checking these items first. Great car, I love mine more today than when I purchased it but it's not a Honda. Best of luck
