Removing c55 spark plugs
Subscribe
Sep 13, 2012 | 12:46 AM
Does anyone know if I need a special type of boot puller to take out the spark plugs? Or if they screw out? I'm slightly misfiring (no CEL), and I want to see if my plugs are still in good condition or if they need to be changed. Thanks!
-mike
Reply 0
Sep 13, 2012 | 02:06 AM
pm'ed
Reply 0
Sep 13, 2012 | 02:16 AM
Quote: pm'ed
Just replied. Thanks for the advise, I appreciate it.
Reply 0
Sep 13, 2012 | 07:23 AM
Could you send that pm my way?
Damian
Reply 0
Sep 13, 2012 | 12:57 PM
Riddler, can you please post up the PM for all of us?
Reply 0
Sep 13, 2012 | 01:44 PM
I would suspect dirty fuel injectors over spark plugs, but I'm usually wrong.
Reply 0
Sep 13, 2012 | 03:52 PM
Okay,
I basically said you need a 17mm wrench, and use the open end to pry out the wire/boots off each plug as some might be difficult to take off. The drivers side plugs in the rear are a nightmare
Also will need a swivel attachment 3/8, in order to get to the plugs in the rear as space is very very tight. If you have big hands forget about it
I replaced my valve cover gaskets at the same time, and the passenger side was easy, but the drivers side requires disconnecting the fuel line to the rail.
Reply 0
Sep 13, 2012 | 03:53 PM
Also slight misfire can be old wires. If you have or know someone with STAR computer, they can see where it is slightly off, so you can pinpoint which wires/plugs may be suspect
Reply 0
Explore
Subscribe
Currently Active Users (1)
