my dyno grap
Old Nov 8, 2012 | 01:53 PM
super-amg's Avatar
c32 amg
my dyno grap
here my dyno results , i have a sc pulley , headers and tune eurocharged , its normal this results? the temperature was in 90 F , and the car limit in 6000 rpm , i want run 12..... seg in 1'4 millle
what recomend me?
Old Nov 8, 2012 | 01:58 PM
C_DirtyTwo's Avatar
a land yacht.
Not gonna get a 12 second number with that power. It does look low, maybe a bad IC pump? Or could have been heat soaked
Old Nov 8, 2012 | 02:03 PM
AMG3.2's Avatar
C63 AMG, P30
Yeah, those numbers definitely look low. I believe the E/C sheet states 330 wheel or something close to that.
Old Nov 8, 2012 | 02:06 PM
super-amg's Avatar
c32 amg
my ic pump its perfect johnson 2 mouth use , how i can check heat soaked?
Old Nov 8, 2012 | 02:09 PM
super-amg's Avatar
c32 amg
i need yours help with this , i run 13.6 60ft 2.36 106 milles
was a dynojet
Old Nov 8, 2012 | 02:23 PM
C_DirtyTwo's Avatar
a land yacht.
there isnt really a way to determine if the car is heatsoaked per say, but you can definitely feel it when driving. Supercharged cars (well all cars, but especially f/i) love cold air. If its hot out, your car will be slower. So maybe the 90 weather played a factor as well. Do you have a heat exchanger or an intake?
Old Nov 8, 2012 | 02:31 PM
super-amg's Avatar
c32 amg
yeah , in the night or when its rainin the temperature low to 70 F amd the i feel much more fast ,
stock intake , and stock heat exchanger
i run 13.6 with bad 60ft , if i can do 2.0 in the 60ft , i run 13.0
Old Nov 8, 2012 | 02:55 PM
Capn's Avatar
03' CL600
Was this a mustang dyno?
Old Nov 8, 2012 | 04:25 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
You're really limiting your power with the stock intake. At the very LEAST, get a Code3 or fabricate one. The Stock heat exchanger will also contribute to heat soak since you're running extra boost.
Also, what wheels are you running? OEM? I used to have heavy 19's and it really lowered my dyno numbers.
Old Nov 8, 2012 | 10:16 PM
jturkel's Avatar
02 C32 AMG
did you ever dyno you car stock? or is this your first dyno?
Old Nov 9, 2012 | 06:52 AM
super-amg's Avatar
c32 amg
here the temperature its to hot , 90f always , in the night low a litter 75 85 F
I used c55 wheels 18 . tires 245 40 18
Old Nov 9, 2012 | 06:55 AM
super-amg's Avatar
c32 amg
when i boght i dyno , and give me 215 hp , but have the catalytic fail , spark plug , ic pump ,
Old Nov 9, 2012 | 06:57 AM
super-amg's Avatar
c32 amg
here my car
Old Nov 9, 2012 | 03:45 PM
ghiaguy's Avatar
C55 AMG, 300D-T & Karmann Ghia
well, it looks really good- that's important. i think heat is your biggest enemy. During dyno days my old tuner started setting up huge warehouse fans in front of the cars, supposedly made a difference in some of the high horsepower cars.
Old Nov 10, 2012 | 12:33 AM
super-amg's Avatar
c32 amg
If i buy i new heat exchange help me with this weather hot?
Where i can buy one ?? Fits in c32
Old Nov 11, 2012 | 12:06 AM
super-amg's Avatar
c32 amg
Today i can 2.0 in the 60ft . My best time as 13.4 @105 i want run 12 !!! Heltp me
Old Nov 20, 2012 | 07:39 PM
super-amg's Avatar
c32 amg
today i dyno again , my result was 315 whp with intake needswing , but i very disapoint , i order a new heat exchanger ,
how many hp i need for run 12 second?
Old Mar 27, 2013 | 07:08 PM
JamesC32's Avatar
2003 C32 AMG, 2015 RAM 1500 4x4, 2012 Merc GL450
I got 315whp at about 5700rpms and I have the 181mm crank pulley, Eurocharged tune, headers, K&N filters, and split my cooling system, it was 74 degrees Fahrenheit, I thought it was pretty low, really disappointed 2003 C32...
Old Mar 29, 2013 | 10:04 AM
super-amg's Avatar
c32 amg
What its your time james?? In 1/4 mille
I have the same you and in dynoyet have 320whp
Old Mar 29, 2013 | 10:20 AM
JamesC32's Avatar
1/4 mile
I have not done a 1/4 mile time yet so I dont know,, do you have the same mods as I also? next weekend I plan on changing my log style headers out for longer tube ones and putting another torque converter on with the hopes of getting my numbers up,, and if I'm happy with the results I'll be looking for a Quaife LSD
Old Mar 29, 2013 | 10:30 AM
super-amg's Avatar
c32 amg
Yeah the same of you , and i m very disapoint too , let me know the result , for do the same , i want more power , next week i going to change my spark plug and fuel filter
