Sachs vs Bilstein vs Koni
Bilstein seems to have the best reputation and I've found all four corners for $700
Koni's are a little more performance being adjustable but $400 per strut seems prohibitive.
Input? Alternatives?
This is the best price I could find on Bilsteins. Anyone find cheaper?
http://www.tirerack.com/suspension/S...2&autoModClar=
Both have lifetime warranties w/ a receipt, so that's a wash. If the car was to do double duty as a daily and track car, I might try some Konis for the adjustability. Full soft for daily duty and full hard for track time.
From what I've heard the OEM C55 shock set is the tightest.
You can check out getmercedesparts or rmeuropean for oem parts.
As far as sachs, bilstein, and koni goes. Sachs made the oem AMG shocks for c32 and 55. Bilstein sport shock is usually stiffer. Koni are adjustable, but if you are spending $1200 on shocks, you might want to consider coilovers at that point. H&R comes in at around $1100. Other brands like BC racing, TEIN, etc are also around thay price range.
I will eventually go to coilovers at some point though. Chances are I'd do the Bilstein PSS9 Coil-Over Kit.
http://www.koni-na.com/cat_search.cf...TOKEN=78930936
I plan to install the shorter c55 bump stop and while I'm in there change sway bar links, wheel bearings and strut mounts.
Can I install the upgraded c55 strut mounts in my c32?
Do I need to / can I use c55 sway bar links?
https://mbworld.org/forums/showthread.php?t=233141
Suspension: Compared to the C32, the C55's AMG springs are uprated by 20% (stiffer) in the front, with no change in the rear. The uprated dampers are digressive and have been increased by 30% in bounce and 10% in rebound at the front, and 15% in bounce and 10% in rebound at the rear. The bearings of the front suspension are stiffer to improve steering feel and geometric precision. The elastokinematics were reworked on both axles: Both the tension strut on the McPherson three-link front axle and the spring suspension link of the multi-link independent rear suspension are harder.
The ride is slightly firmer than original but very acceptable to the point of comfortable.
High speed cornering is much much much better, flatter and inspires confident.
Well worth the price, not sure how they compare with H&R & KW tho.
https://mbworld.org/forums/c32-amg-c55-amg-w203/233141-differences-between-c55-c32.html
you can also use the endlink. the 55 as well as the 32 comes with the 12mm endlinks.
