C55 No Audio
Old Feb 27, 2013 | 09:20 PM
Agent Orange's Avatar
C55
C55 No Audio
My C55's audio has gone completely out. There is absolutely zero audio coming from any source. I looked at the wire diagram and pulled the appropriate ones that were listed in other threads. Nothing seems to work.
I should note that after it went out the first time I started the car and went for a drive and it started to cut in / out and then started temporarily working again but after I turned the car off it hasn't worked again since.
I can change the song from my unit and steering wheel, I can check to see if it's playing by watching the time of the track, I can even go in and mess around with the surround sound / speech / normal sound settings.
I'm getting really frustrated because I'm running out of options and I'm fearing it's something remotely serious.
Is there anything that I've possibly looked over / not done?
I appreciate any and all responses.
Old Feb 27, 2013 | 09:25 PM
ricecooker713's Avatar
C63 E63
You have check all the fuses? Have you check the fuse for the CD changer?
Sounds like a component of the MOST ring is off which causes no sound
Old Feb 27, 2013 | 09:31 PM
C55
It's hard to read the diagram since it's all in German and I'm not fluent in German by any means.
I thought I checked all the fuses, I may not have. Is it located on the driver side?
How do I get that back on? Is it something I could fix myself?
Old Feb 28, 2013 | 10:29 AM
C55
Anybody?
Old Feb 28, 2013 | 02:49 PM
C63 E63
check fuses
#24 cd changer
#64 & 36 radio
#16 satellite radio
#26 audio (amp)
Old Mar 1, 2013 | 06:30 PM
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
I believe I've heard of these having a water leak in the trunk and killing the amp. Might want to check that.
Old Mar 1, 2013 | 10:49 PM
JonMBZ's Avatar
06 C55, 09 E350
Probably a faulty amp or command, I don't think our cars have the water drainage issue.
Old Mar 2, 2013 | 05:12 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
I have an audio 20 head unit from my C55, used less than 2 years or 8k miles. If that ends up being what is defective, let me know. I'll sell it for the going eBay prices.
Old Apr 2, 2013 | 12:51 PM
C55
Checked all the fuses and everything looked good. Whenever I go to change my sound settings it changes from CDO to CD. Whenever audio actually worked it would stay on CDO. Is there a setting or something I'm missing?
Old Apr 2, 2013 | 05:25 PM
ghiaguy's Avatar
C55 AMG, 300D-T & Karmann Ghia
On two separate occasions my audio was extremely garbled after heavy rain. All stations/inputs are effected until I shut the car off and left it for a few hours. Really weird, although I have never lost audio completely and mine was only intermittent. Any driving in bad weather before you lost all audio? I would check that amp either way (though I personally have no experience with it)
Old Apr 3, 2013 | 03:26 AM
C55
It stopped working completely after a car wash one day. That wasn't the first car wash I had given it though so I'm not entirely sure if it's that. Where can I check the amp at?
Old Apr 3, 2013 | 06:41 AM
91RS's Avatar
The right side of the truck. I bet you have a water leak.
Old Apr 4, 2013 | 07:17 PM
macbryanie's Avatar
Porsche 2004 911
I had this. It was my first repair with the 32. But with my experience the comand would fire up and there would simply be no audio. Dirt etc blocks some of the drainage holes around the trunk seal and water finds its way to the amp. Fries it. I had the amp repaired as it costs a small fortune for a replacement in AU but not so bad in the US : http://www.ebay.com/sch/sis.html?_nk...d=150614923885
Old May 23, 2013 | 07:59 PM
K3nD's Avatar
2013 C63 Coupe P31
this exact same thing happened to my 05 c55 about a month ago. i grabbed the fuse box diagram and looked over ever single fuse that i thought had something to do with audio/radio and they were all good. so i took took the fuses out one by one and shoved it back in place.... and wa la the audio worked again. you should try it.. but i dont think mine had anything to with the amp being wet becuase when it happened it was a sunny day.
Old May 25, 2013 | 12:33 AM
cldriver's Avatar
AW '05 C55
Just a thought, disconnect battery for 30 sec and reconnect. The electronics on this car can act strange, I've experienced the radio cut out, front head lights that won't light up. So maybe rebooting everything might do the trick.
Old Dec 4, 2013 | 09:07 PM
Quickvr4's Avatar
05 C55 AMG
Mine is very weird because my Command Unit has 0 function in the audio screen when it is on. The map and Nav work but without sound. The audio screen displays the radio station that is was last set to and i cannot even seek. It seems like the Command is Frozen when in the Radio screen.
Any feedback?
Old Jun 2, 2014 | 03:25 AM
FutureAMGxx's Avatar
C55 AMG
What kind of solutions have you guys come to with this issue? I have an 05 C55 and I have had similar issues. I have searched throughout the forums for answers and have only found people in similar situations. The first time it happened to me was on a sunny day, no water anywhere and I turned her on and like most people I had all command controls just no audio. I let it sit for about thirty minutes while at lunch and when I came back it worked fine. Now after a week of it working fine I gave her a car wash and hopped back in to find the command working but without sound yet again. Is it fuses or amp or what? What was your guys' fixes?
Old Jun 16, 2014 | 09:32 AM
jneal3110's Avatar
04 C32 AMG (sadly sold), 05 CLK55 Cab, 08 R350 4Matic, 15 GLA250 (sadly bought), 75 VW Westfalia
I had the exact same experience - zero audio with head unit turned on, trunk leak had fried the amp, had the amp repaired and *thought* I had the trunk leak dealt with but turned out not so the next time through a car wash I started hearing the pre-death sizzle/crack of water getting on the amp again. I gave up trying to fix the leak and instead fashioned a bit of copper flashing to act as a 'roof' over the amp without disrupting the air cooling flow, and have had no issues since. I think fixing the leak requires re-installing the rear glass and just haven't gotten to it yet...
Old Jun 25, 2014 | 06:09 PM
DG83 C55's Avatar
05 C55
And on the 05 C55 it is located on the left side of the trunk? Is there a DIY for getting to it, even a quick write-up? If not, I may do one when go to troubleshoot mine.
Damian
Old Jun 25, 2014 | 09:25 PM
jneal3110's Avatar
Damian
Pretty sure it's on the passenger side, unless they made a change from '04 to '05; getting to it is a matter of taking out the interior cladding, which is held in with various plastic button-clips. The plastic trim over the bottom of the trunk opening has to come out first. There's another plastic piece right behind the back seats that covers the phone control unit that also has to come off (torx bolts holding luggage clips). After that it's just scanning the surfaces of the various cladding pieces looking for button-clips.
Old Jun 26, 2014 | 11:44 PM
BF_JC230's Avatar
2005 w203 C230
Water leaks...huh...that's not good.
I have images in this MHI Thread on removing the AMP...
https://mbworld.org/forums/c32-amg-c...omplete-4.html
Old Jul 1, 2014 | 04:23 PM
ambit's Avatar
09 CLK550
Had the same thing happen in mine, was a dead amp:
https://mbworld.org/forums/clk-class...-618-70-a.html
Old Jul 1, 2014 | 08:09 PM
Duncan64's Avatar
C55 AMG
I got an amp for sale
