C32 wierd electronic failure
Have tried to search after a topic similar to mine, but I cant find any, so I hope some of you guys can help me!
I have got two problems, but i think that if I solve one, both will be solved since they are both related to electronics.
I bought my car for like four months ago and when the weather started to get freezing cold, like -20 degrees celsius then my battery were dead. Charged it up and dead the next day. I found out that it was the electronic seats that was draining it, so I unplugged the seats and got to the repair shop where they fitted a new fresh battery.
No problems until a couple of weeks ago when I were driving in the snow and the ESP needed to work alot. Sometimes when the yellow ESP-triangle comes up - then the Comand dies (just for a few seconds) and my headlights starts to flicker/blink a bit.
And now problem two.
This morning when I got home from work and have parked my car at my parking spot it just were about to die. I have had this problem like two times before under the same conditions. It's seems like it's when Im about to put it in (P) from (D). But this morning did I get "ESP Visit Workshop" and "Right Low Beam not Working" after the car did recover (it does not die, but it just behave like it would and all electronics stops working for a few seconds). I have got similar malfunctions before and it have just been turning of the engine and restart and they are gone. But when I turned of the car then ALL electronics died, like that the battery were dead. Could not lock the car or turn the key to start the car.
But I sat in the car and tried to browse and find something on the internet and after like five minutes it did light up (had my door open) and everything were normal again.
Anyone have any idea what this can be?
/Kim
As soon as I put in the (P) on the shift lever the car acts like it's dying. I let it stand for like three minutes and it did the same thing over and over for a couple of times.
Pulled out the key and the car is dead now. Nothing works. Been waiting for 10 minutes for a "reboot" like in the morning. But nothing is happening.
Will see if the car works in an hour or so. Have a meeting now that i must attend to.
Check that first.
https://mbworld.org/forums/c-class-w203/262131-temjinx2s-20-seat-control-battery-drain-fix.html
Also on the seat fix. I have checked that thread before and im just waiting for some better weather before I will do that. Too cold now and have not got any garage to be in. So at the moment im stuck with one seat position.
Again thanks! Just want my car to work fine, cause its a really fun and nice car. I will now try to sell my Skyline and drive this all the time instead.
I have now had the car for four days and not a single problem and the voltage shown by my Comand unit is alot more stable (jumping between 14.3-14.5 instead of 13.3-14.8).
Thanks all for the ideas!
Also to the poster above me, I live in Sweden and its a Nissam Skyline R33 gts25t. PM me if you want to know anything else.
Thanks!
