Fixing a tiny ding on the front. How?
Thanks,
John
1 Hot Glue Gun
4 Glue Sticks
1 Dent pull device with soft pads so not to scratch car.
2 plastic disks which is placed over dent (depending on size of dent determines disk)
1 Bottle of area cleaner.
1 Plastic post dent former
1 Car scrapper (looked like a spatula)
Just like anybody I was skeptical about the results. But I cleaned the spot (about an inch in diameter) put some hot glue (not really glue but a plastic adhesive that when cools forms a bond on your car) and placed in middle of dent. Placed plastic disk onto melted glue. When glue dried, I positioned the dent pull device (and soft pads) on each side of the dent and screwed in plastic disk onto glue. I kept on screwing until I heard a 'POP". The pop was a combination of dent and plastic disk being popped off the car. I looked in the area of the dent and IT WAS GONE. The directions also states that if the dent is larger or it did not pull out then try again.
With my new toy in had I tried to do the same to my wife's car. She had about three small dents and "low and behold" it worked fine on her car. The cleaner has a little alcohol in it so when done with pulling out dent use cleaner and it looks just as new (predent.
By friend came by and saw the miraculous results so he asked if he could use it on his BBQ grill. When he bought the grill he dropped it on the ground and put a pretty big dent in it. As you know the metal gauge is thicker than your average car. He was able to pull most of the dents out but the spot looked uneven so with the plastic post dent remover he was able to reform the spot to original shape If you look real close to the spot where he tried to pull dent out you can see that something happened but it still looks a lot better then before. Try it you will like it. Besides with the money you save you can purchase something for your baby (C32). Good luck!
