C32 AMG auto transmission ran with no oil Help
To my understanding the 32 shares the 722.6 as other Benz's however they do slighty differ,you need the one that can handle the load (one from the amg), here is a rebuild ; https://mbworld.org/forums/w211-amg/...uild-pics.html
And they sell rebuild kits from precision Etc (http://www.transmissionkits.com/)
My advise would be to try and hold off to see what some of the others members on this forum have to say, as some may have first hand experience and ultimately save you headaches and cash. Have a search too as there are a few threads on the 722.6. What happened to your gearbox I don't know as I am too inexperienced mechanically.That's all I can advise, sorry.
It then take about 1.5-2days to rebuild.
You will also have to rebuild the torque converter as the clutches inside may be toast.
While you are at it... if your a rev head I would get the torque converter stalled up.
Also,,, get an exchange valve body or reem and put a kit into it... you will get heaps better shifts.
If you want to ship it to oz i can do it for you.
its a big job but my C32 now goes like stink.
I have made the sifts faster and crisper... the stall makes a big difference off the mark.
I have also had Eurocharged reflash it, put a 61mm pulley on and K&N's.
If you need any help or advice let me know.
this has now gone to court and the judge is asking if the computer on the car measures the oil level in the gearbox at all, when all this happened I had no lights come up for low oil in gearbox or anything as far as I'm aware it can only be measured using a dipstick am I correct in this?
Edit: My thoughts aren't needed anyway. Looks like your issue is solved.
Sorry about the lack of punctuation, I was a bit pissed off and was typing in a rage. Thank you for picking up on this. That issue is now resolved.
Thank you for your reply this helps me allot and relives me as the judge has said if there was then I would be partly liable as I should of stopped if it came on but nothing did.
