Help.. Quaife LSD installed - Gear whine??
On the test drive going forwards is fine with no noise but as soon as i lift off the throttle and coast it would whine until i step on the gas.
In reverse gear it would whine too.
Any ideas would be appropriated..
They use different thickness circlips to adjust right and left position and preload on bearing.
Check back lash to.
I´ve got a lot of years behind me in tuning cars, but i always leave theese jobs to people who knows what they are doing.
Before it´s totaled,, redo the job. let trained personel do it.
Since there are some SRT's that use our rear end, I'd guess that if they can source parts for the SRT LSD's they can get the shims for you. Good luck!
Les
SRTs share the same pumpkin as the SLK, and the pumpkin on the SLK is different than the C32s. This means both of them are different from what's on the C32, so no cross shopping for us
I will have the diff dismantled again tomorrow to check everything again.
I hope it's simple, I pray I haven't damaged anything.
Will let you know my findings.
This forum is full of helpful people
It was the circlips, installed them in the wrong side. (Make sure you mark them to indicate left & right side as the thickness is different)
Left thickness: 4.1mm
Right thickness: 4.2mm
putting them in the incorrect sides was enough to create the whining noise.
I guess when installing I have now learned that all parts should be replaced in exactly the same position, especially when it comes to bearings shims and clips.
Happy man now..
Thanks all..
Just by putting the spacers/clips back in the factory position is no assurance that things will be set up properly. When you look at the tolerance stackup (bearings, Differential, gear etc.) it is very easy to be off by .001"-.002" and wind up with a noisy gear install.
