C55 coolant leak
Old Jun 18, 2013 | 09:29 PM
Richardmozis's Avatar
E55 AMG
C55 coolant leak
I have got a small coolant leak at the front of the engine which gets onto the belt which is damp and smells of coolant. What should I do? Would radiator stop leak products work? My coolant reservoir has been full for months so this leak is small but it smells. Here is a photo of the mess.
Old Jun 19, 2013 | 11:22 AM
DG83 C55's Avatar
05 C55
Can you see if the leak is coming from the waterpump that is right in the middle of the belt? Might need a mirror but you should be able to see if its coming from there.
Damian
Old Jun 19, 2013 | 02:42 PM
JonMBZ's Avatar
06 C55, 09 E350
Fix it right, find the leak and replace the part.
Old Jun 19, 2013 | 04:18 PM
Saaboteur's Avatar
eclectic assortment of cars
The water pump is behind the pulley that is blurry in the photo, on the left. If it's not leaking from there, the other area where coolant flows is at the thermostat, more centrally located, where the upper rad hose connects. Check that out too. Best of luck!
Old Jun 19, 2013 | 04:20 PM
Saaboteur's Avatar
Oh, almost forgot - coolant also runs through the oil cooler, there are a couple lines there that lead to the water pump cover closer to the left/driver's side (but to the right in the picture) of the motor. Have a look at those as well.
Old Jun 20, 2013 | 12:46 AM
E55 AMG
So basically I had a good look at the water pump, thermostat, and oil cooler. They are all clean. After another good look the worst area is near the bottom on the drivers side.
Old Jun 20, 2013 | 06:25 AM
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
That looks like the A/C compessor that's leaking. AC refrigerant oil with dye is typically green. The coolant in these cars should be blue unless someone has changed it to green (which would be stupid).
And for the record, DO NOT use stop leak products! All they do is cause more problems clogging up all kinds of stuff, like small coolant passages and the thermostat.
Old Jun 20, 2013 | 03:15 PM
E55 AMG
The coolant is supposed to be blue? I looked at multiple clk55 and c55 cars locally and they all had green coolant. Also there is a coolant smell coming from the engine bay and filling my garage, It can't be the ac causing that smell.....
Old Jun 20, 2013 | 04:12 PM
Saaboteur's Avatar
My Mercedes coolant is orangey-yellow. But yeah, as 91RS said, the green is AC refrigerant, and it looks to be pooling at the AC compressor's pulley.
Can you see if the AC lines off the compressor are loose? Could be one of the rubber o-rings on the lines have blown.
Are you getting cold AC?
Old Jun 20, 2013 | 07:37 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
I thought the factory MB coolant is blue.
Old Jun 21, 2013 | 12:28 PM
Scott Simoncic's Avatar
2001 CLK55 AMG
Mine is blue... That's what Mercedes of San Jose put in from a white jug that Said Mercedes Benz Anticorrosion / Anti-Freeze on it.. And yes, that has all the look of being dyed refrigerant from the air conditioning system..
Old Jun 21, 2013 | 02:51 PM
E55 AMG
Thanks for the help guys. I should probably flush the green coolant and put in an MB one.
You guys are talking about the mess being the ac compressor. I do get ice cold ac in the car fast. The previous owner had the compressor replaced before I bought the car.....
Old Jul 2, 2013 | 04:07 PM
Saaboteur's Avatar
Richard, did you get the leak sorted out?
I have to clarify my previous comments re: coolant (post #9). I was confused because my buddy had given me some spare Land Rover coolant in a Mercedes jug, and that stuff is orangey-yellow. I was reminded of this the other day when I picked up some genuine Mercedes blue fluid! Doh! Good thing I never put any of that into my AMGs!
Old Jul 2, 2013 | 06:52 PM
Newzchspy's Avatar
PLAID
Other than the above, dimes to donuts we got an IC leak going here. Very common with the C32/SRT-6
Old Jul 2, 2013 | 07:59 PM
Saaboteur's Avatar
Except Richard's car is a naturally aspirated C55!
Old Jul 2, 2013 | 08:15 PM
Newzchspy's Avatar
PLAID
Oops, thought it was FI! My bad
