Did I install my wheel bearings incorrectly?
Old Jul 25, 2013 | 12:34 AM
AMG3.2's Avatar
C63 AMG, P30
Hey All,
I installed my front wheel bearings yesterday and have been experiencing a noisy-er ride than usual.
There is a noise that cycles at around 20-30 mph, then goes away after that.
Also, I'm still feeling some sort of vibration which is why I started the wheel bearing project in the first place.
There is no play in the wheels when thrusting at 6 and 12 o'clock positions.
I looked through many install threads and did everything according to what I found - especially backing off the retainer nut 90 degrees after the hub is tight enough to barely turn.
What should I do? Is there anything I missed?
I'd hate to take it into a shop as they tend to treat cars fairly poorly and I baby my C32...
This forum has helped me greatly so I thank you for the help in advance!
Old Jul 25, 2013 | 11:11 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
did you change the inner and the outer wheel bearings?
Old Jul 25, 2013 | 08:40 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
while i dont know about our cars specifically, if they arent right arent they supposed to hum?
Old Jul 25, 2013 | 10:45 PM
fleishman's Avatar
2002 C32 AMG
I had a hum around 60 after doing new bearings. I tore down again and found that one was not tight despite setting and backing off 1/4 turn. I tightened again and backed off 1/8 and it is now prefect. Turn your wheel when you hear the hum. A wheel bearing will hum under load, turn left and load right bearing, turn right to load left bearing.
Old Jul 26, 2013 | 12:25 AM
AMG3.2's Avatar
C63 AMG, P30
Yes, both of them.
These are indeed humming. Not to loud, but there is still a noise.
Alright. I'm just afraid of going to tight since they can overheat and fail. I've already tightened twice.
So if I'm hearing humming that means I should tighten?
Old Jul 26, 2013 | 10:02 PM
ricecooker713's Avatar
C63 E63
It's hard to judge how tight you went before backing it off. Were the bearings already packed with grease?
Old Jul 27, 2013 | 02:10 AM
AMG3.2's Avatar
C63 AMG, P30
Nope. I packed them myself prior to install.
Old Jul 27, 2013 | 08:34 AM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
The old school way I used to use was to put the wheel back on and tighten the adjuster nut until I got the slightest amount of freeplay when rocking the wheel at 6:00 and 12:00. The washer behind the nut should just be movable with a screwdriver.
Now days I use a dial indicator and the MB spec for end play.
