C 55 brake shudder
Think about solid vented rotors, or slotted vented; they last longer and have more material to soak up the heat which in turn will prevent warpage . It may not look as cool tho as the OE drilled rotors....
Def try the two feet on the brake pedal from 50-0 first a few times. Perhaps you do just have some pad material built up.
Your assertion that slotted or non drilled rotors is better at stopping deposits is not true. Drilled rotors tend to crack under extreme braking but they get the excess heat out.
Please see the articles on Stoptech's website
http://www.stoptech.com/technical-su...nd-other-myths
Very true that drilled rotors often develop cracks. Heat and gas can escape easier with drilled (the whole idea) but also the rotors will heat up faster and warp faster with drilled under heavy usage due to less material (metal) to soak the heat. Simple physics.
