13.2 timeslip stock
Old Nov 13, 2003 | 02:18 PM
Bux's Avatar
Bux
G
13.2 timeslip stock
rt .555
60' 1.9
330' 5.5
1/8 8.5
mph 82.3
1000 11.1
1/4 13.2
mph 104.9
Old Nov 13, 2003 | 02:26 PM
carl's Avatar
Thumbs up yeah
yeah baby!
i got an 03 too!
and i won my friends 02 e46 m3
M3 need some skill to get faster than C32.
MotorTrend have a new article on our 03 C32, not 02s!
that's the only magazine have reviews on 03 C32. the numbers are impressive... compared to 02 reviews done by C&D and R&T.
are 03 C32 faster?... or 02 US spec C32 is slower?
magazine in europe and asia get 4.7 and 4..8 sec on our cars...
Old Nov 13, 2003 | 03:03 PM
ronnie0738's Avatar
2003 Nissan 350Z
maybe it has to do with octane of the gas? if they tested the C32 in cali with 91, it would be much slower than with 93 or 94 elsewhere.
Old Nov 13, 2003 | 03:32 PM
Bux's Avatar
Bux
G
- i had an 02 c32 also that ran 13.2
the night i went, a smurf blue 6spd stock m3 wanted to race me and he also ran a 13.2
Old Nov 13, 2003 | 03:33 PM
RapidG's Avatar
C32AMG
Octane Myth
I keep seeing this myth perpetuated on this web site and others, that if you use higher octane, you'll have faster time, better acceleration, etc. You won't. If you use the octane your engine is designed for, that's the best you'll do. Octane ain't a "power" additive. Octane is an anti-knock compound. If the "octane myth" were true, we'd see horsepower curves from manufacturers or others with octane on one axis and horsepower on the other. Ever see one? Of course not. Horsepower doesn't vary with octane, above that for which your engine was designed. Only exception is if you have excessive carbon deposits on your valves, then you get what's called "octane creep", that is, a car which is designed for 89 octane will only run without knock at 92 or 93.
You can put this myth on the shelf with the "K&N Filter" myth. That filter doesn't improve performance, either. We've seen some dyno results posted here and elsewhere whichproved that fact.
Off my soap box, and back to driving the hell out of my C32!
RapidG
'02 C32 Black Opal/Blue
Old Nov 13, 2003 | 04:20 PM
ronnie0738's Avatar
2003 Nissan 350Z
RapidG - What you said is true, but only if your ECU is not programmed to use higher octane gas. For a ECU programmed for 91 octane, it should be able to compensate if 87 octane is put in accidently by backing the timing, so knock is avoided but performance would be dramatically decreased. By putting in 93 octane, when the ECU is only programmed to 91 there would be no difference in timing or performance compared to 91 because the ECU wouldn't know better. Since the C32 ECU can be switched to a 93 octane gas setting, there will be performance gains over 91 octane.
Old Nov 13, 2003 | 04:35 PM
jimmyp's Avatar
13.07- 107.3- 2002 c32
Old Nov 13, 2003 | 04:39 PM
jcanabal's Avatar
2006 SLK 55 AMG
JimmiP ....that's really good for stock!!
Old Nov 13, 2003 | 05:56 PM
Bux's Avatar
Bux
G
wow 13 flat thats probably the fastest stock time posted if thats being on stock tires?..
Old Nov 13, 2003 | 06:04 PM
hammyoni's Avatar
C32
many cars, especially cars that run bosch motronic systems do benefit from higher levels of octane, because it can adjust. I have seen dyno plots increase with only boosts in octane. So not all cars benefit, but many can, even with stock ecus.
Old Nov 13, 2003 | 07:01 PM
ntguru's Avatar
C32 AMG
The C32 ECU is set to 87 or 89 (pretty sure 89) by default. There is also a 91 and 93 setting. When I had mine set to 93 there was a slight but noticable increase in performance.
That said, I don't think you're going to go from 13.5 to 13.2 just on octane tweaks.
I don't think the original 13.2 person said anything about the tires they ran?
Old Nov 13, 2003 | 07:11 PM
Bux's Avatar
Bux
G
i was on stock pilot sports
Old Nov 13, 2003 | 07:33 PM
ronnie0738's Avatar
2003 Nissan 350Z
Do you guys know how to change or check the octane setting? Does the dealer change it for you?
Old Nov 13, 2003 | 08:17 PM
carl's Avatar
i know nothing about these stuff...
but to me... i believe every car has different speed/problems/quality, even same model...
Old Nov 13, 2003 | 08:55 PM
ntguru's Avatar
C32 AMG
Ronnie, the dealer changes it with the diagnostic computer. If you want yours changed I suggest you makes friends with one of the knowledgable techs at your MB Dealer.
Old Nov 13, 2003 | 09:29 PM
Bux's Avatar
Bux
G
yup thats what ya gotta do but all the ones i talked too were all like "all i know is just to service the car ..know nothing about tweaking performance"
Old Nov 13, 2003 | 11:18 PM
ronnie0738's Avatar
2003 Nissan 350Z
Good to know...thanks for the info guys. What is it set to default? 91?
Old Nov 14, 2003 | 08:27 AM
ntguru's Avatar
C32 AMG
Ronnie, no it defaults to the lowest, which is 87 or 89.
Old Nov 14, 2003 | 11:19 AM
ronnie0738's Avatar
2003 Nissan 350Z
oh dang, i gotta make a buddy at the dealer then.
Old Nov 14, 2003 | 03:21 PM
jimmyp's Avatar
13.07 bone stock car with p-zero.I have nitto drag tires now and can not get a good 60ft.I think too low of a tire pressure hurts the 60ft.I will try them with more air to see if I can run my times again.Thanks
Old Nov 14, 2003 | 04:02 PM
ronnie0738's Avatar
2003 Nissan 350Z
jimmy - what octane were you running? did you change your ecu octane setting at all?
Old Nov 14, 2003 | 10:52 PM
jimmyp's Avatar
I used sunoco 94.But tonight I went to the track with the nittos and only ran 13.7 at 103.The car has ran slower ever since I changed the tires.The side wall height may have some effect on the tranny.I will drop it off to see if it threw any codes for the trans and see what happens but I need those 13.0 back.On a side note I saw a E55 run a 12.4 at 118 tonight looked real good but I thik I will do the evo sport upgrades and go with the 375 whp for about 25g less!
Old Nov 15, 2003 | 01:22 AM
Vadim @ evosport's Avatar
C32 AMG
ro0zy: Good numbers!
Congrats!
60 foot is awesome for street tires.
Old Nov 15, 2003 | 10:31 AM
Bux's Avatar
Bux
G
i just went to the track again with nittro drags and pulled a 13.1@106 and 1.9 60ft (hoping for 1.8) -man your car must have been real hyper that day to run a 13.0
