torque the wheel lugs 80-85 ft/lb?
Old Nov 13, 2003 | 03:37 PM
Bux's Avatar
Bux
G
Question torque the wheel lugs 80-85 ft/lb?
what do i do it at?
Old Nov 13, 2003 | 10:12 PM
hammyoni's Avatar
C32
too lazy to hit the manual, but ive always stuck to the rule of 90.
Old Nov 14, 2003 | 11:57 AM
AMG BRED's Avatar
CLK63 Black Series
90 is i think too much... might damage rotors.. someone correct me if i am wrong.
Old Nov 14, 2003 | 12:22 PM
hammyoni's Avatar
C32
many cars are over 100. Im going with my vw and audi models, always 89-90. Of course MB may be different, but ive always felt the 89 was conservative. All cars are different, best to find it in the manual or from the dealer. Ive been doing my amg's at 90.
Old Nov 14, 2003 | 12:24 PM
Bux's Avatar
Bux
G
discount tire and another benz board said around 80-85 i have looked on the gas lid and manual couldn't find any info
Old Nov 14, 2003 | 12:46 PM
hammyoni's Avatar
C32
try calling the service center at your dealer. When Ive done 80, and check to retorque the lugs a week later, they arent in there too tight. This is why I stick to 90. They are tight, but dont take super strain to remove.
Old Nov 14, 2003 | 12:52 PM
AMG BRED's Avatar
CLK63 Black Series
so tempted to press that tele-aid button and ask them.. never used it
Old Nov 14, 2003 | 02:27 PM
RapidG's Avatar
C32AMG
Torque
At MBCA events, we use 82 ft lbs of torque to check cars before they go on the track. That's the "offical" mercedes torque. BUT if you use anti-sieze compound, you should really torque at a lower level. I have a manual which gives different torque values for the type of lubricant which are on the threads. What you're actually measuring is the resistance between the bolt and the threaded wheel. If a lubricant is used, it stands to reason that the resistance will be lowered at some theoritical "tightness". That said, we ignore anti-seize compound and use 82 ft. lbs. at tracks!
Old Nov 14, 2003 | 04:10 PM
hammyoni's Avatar
C32
Then you open a can of worms on the use of anti-seize compound on lugs...
Old Nov 14, 2003 | 05:17 PM
levelr123g's Avatar
if you look at your manual under changing a tire, it is clearly posted there. i always use 85 lb/ft with NO lubricant.
Old Nov 15, 2003 | 01:35 AM
Vadim @ evosport's Avatar
C32 AMG
80-85
Old Nov 15, 2003 | 08:12 PM
rrf's Avatar
rrf
Yep, clicker torque wrench is always set at 85 for me. Retest a week later, it only takes a couple of minutes.
Old Nov 16, 2003 | 02:20 PM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
volvo lists 81 lb-ft... so it's not low to go 80-85...worse thing to do is warp a rotor by overtightening it....
Old Nov 17, 2003 | 04:15 PM
RapidG's Avatar
C32AMG
80 or 85?
Probably 5 lbs torque one way or another is within the margin of error of most torque wrenches, anyhow, so set somewhere in the middle. 82 or 83 will probably get you somewhere between 80 and 85.
Old Nov 17, 2003 | 04:16 PM
RapidG's Avatar
C32AMG
80 or 85?
Probably 5 lbs torque one way or another is within the margin of error of most torque wrenches, anyhow, so set somewhere in the middle. 82 or 83 will probably get you somewhere between 80 and 85. This ain't rocket science. Torque is not that exact a measurement, anyhow. Depends upon the quality of threads, whether or not they have any lubricant on them, temperature, etc.
Old Mar 27, 2004 | 04:18 PM
Greg Elmassian's Avatar
2003 SL
I've found that anti-sieze as related to clean threads (not dry mind you!) can change the torque by 5-10 ft-lbs.
I'd think 90 dry would be fine, all of the cars I've owned in the last 20 years (corvette, nissan 300zx, audi a8, etc.) have been 90 or so. I'd torque to 85 with anti-sieze.
Greg
Old Mar 27, 2004 | 09:39 PM
smgC32's Avatar
Factory Spec is 80lbs for the C32. This is consistant with most lug bolts with the same diameter and thread pitch. Do no go below, and a few pounds above is OK. I use 82lbs as this is the spec for my other car and is set at that point on the wrench.
Old Mar 28, 2004 | 10:49 PM
carl's Avatar
damn, i used 120 lb.....
since mercedes are always heavier duty than others...
