Anyone know this sound?
Old Mar 11, 2014 | 05:31 PM
c32used's Avatar
LET C32 2002
Thumbs up Anyone know this sound?
Ok haven't been on in a while but still have my 02 C32 with almost 100k miles which I'll reach come Spring/Summer. Anyways I've had this sound since last season but since car runs fine made no big deal of it. I still have over 2.5 months prior to taking her out of storage so have time to work on it if need be.
I don't have codes or nothing like that. It has Eurocharged 185mm pulley and Eurocharged Tune. I've had the PSK installed over 2 Summers now. I thought I remembered a thread with same or similar sound/whine. Opinions?
https://www.youtube.com/watch?v=mavb...ature=youtu.be
Old Mar 12, 2014 | 08:33 PM
c32used's Avatar
LET C32 2002
can't believe no one heard this
Old Mar 12, 2014 | 11:08 PM
02C32guy's Avatar
2005 E55
Sounds like a (really) bad supercharger bearing to me. I've just changed mine for the 5th time since I owned the car. Just hit 190K.
Old Mar 12, 2014 | 11:13 PM
c32used's Avatar
LET C32 2002
Is there a thread with DIY or where to buy a bearing?
Old Mar 12, 2014 | 11:34 PM
cm60k's Avatar
This could help:
http://www.benzworld.org/forums/w203...ercharger.html
http://www.needswings.com/Supercharg...scBearing.aspx
ZAYED,,
Old Mar 13, 2014 | 12:30 AM
c32used's Avatar
LET C32 2002
Old Mar 13, 2014 | 10:27 AM
02C32guy's Avatar
2005 E55
Right now Needswings is the best place to buy the bearing. Attached is the code 3 pulley install guide. The installation would be the same for the regular pulley. If you have the pulley saver kit it's super easy because you don't have to remove the idler pulley.
Once you get the bearing, remove the pulley and take it to your local machine shop and have them press out the old bearing and press in the new bearing. Let them know that it's normal for it to be really tight. Usually they charge $10.
File Type: pdf
Old Mar 13, 2014 | 10:31 AM
cm60k's Avatar
Originally Posted by c32used
ZAYED,,
Old Mar 13, 2014 | 10:33 AM
cm60k's Avatar
+1,
NeedsWings products are great & proved, no regret to deal with them..
ZAYED,,
Old Mar 14, 2014 | 09:28 AM
gwin's Avatar
C32 AMG, 997, Mustang '66
dont need to press out, just hammer the bearing out.
then when you put in the new one, bake the pulley and freeze the bearing, itll slot right in.
Old Mar 14, 2014 | 10:05 AM
c32used's Avatar
LET C32 2002
Thanks this is really helpful. This weekend I'm working on it and gonna pull off belt and manually turn SC Bearing and pullies to make sure which one it is so I can either get the SC bearing from NW or if it's a bearing from Pulley I'll get it from Eurocharged I presume since they are from them.
Old Mar 14, 2014 | 02:41 PM
02C32guy's Avatar
2005 E55
I've done it this way before. It does not slip right in. It's a huge PITA and you have to hammer the crap out of your pulley and bearing. A press does it in 30 seconds without any chance of damaging the $50 bearing or $500-$1200 pulley.
Old Mar 15, 2014 | 03:31 PM
c32used's Avatar
LET C32 2002
Hear the sound of SC bearing turned manually..does it sound bad?
http://www.youtube.com/watch?v=guE2N...ature=youtu.be
Old Mar 16, 2014 | 05:38 PM
02C32guy's Avatar
2005 E55
That's definitely bad. A healthy one makes no sound at all.
Old Apr 4, 2014 | 11:17 PM
c32used's Avatar
LET C32 2002
Question
What you think of this bearing a tad cheaper and free delivery?
http://www.ebay.com/itm/Supercharger...268e03&vxp=mtr
Old Apr 5, 2014 | 12:44 AM
02C32guy's Avatar
2005 E55
It will work fine, but won't last as long as the NSK. I used that one once. I got about 10k out of it before it started making noise again.
Old Apr 5, 2014 | 09:52 AM
c32used's Avatar
LET C32 2002
What you think of this guys procedure?
Old Apr 6, 2014 | 10:23 AM
link146's Avatar
'02 325 xi; '02 C32; '90 ZX; '08 CBR 6RR, '86 V45 Magna
It works in theory. I used the technique to fit bearings before just not in this particular application. It should work but I'd have a rubber mallet handy and some grease in case it requires some persuasion. Or you could make your own press with a length of standard threaded rod from Home Depot, some thick washers and a few bolts. There are tons of ways to make presses I'm just thinking back to shop class.
