C32 owners need your advice/help
New here and this is my first post so apologies in advance if my issue has been well documented before, I have searched thoroughly online though and cannot find an obvious answer/solution.
As a long time BMW M car owner this is my first delve into the AMG world. Just purchased an 02’ C32 which was advertised as having the below:
“65mm pulley, 185mm pulley kit - Needswings Pulley Saver Kit - PLM Heat Exchanger - SL55 intakes with K&N filters - Resonator delete - 2nd cat delete - Primary cats have been replaced with highflow cats - Iridium Plugs - Magnacor KV85 wires - Tuned by Euro Charged with 185 pulley, pulley saver kit.”
My problem is the car runs like crap and bogs/misfires on multiple cylinders when you give it even half throttle. Multiple misfire codes in addition to P0108 - Manifold Absolute Pressure/Barometric Pressure Circuit High Input. Which is throwing the CEL light. I need to get the problem fixed primarily so no damage is caused and I can enjoy the car, but secondly because I can’t get the thing smog’d running like this.
I am assuming (could well be incorrectly) that the 185 pulley is causing the over boost issues and the MAP is shutting down the charger, or something to that effect. From research I have also read that it could be a fuel flow problem.
Not sure where to start with trying to correctly diagnose and fix this issue so any advice or knowledge would be greatly appreciated. I am very mechanically inclined and know my M’s inside out, this is a whole new beast though and I am inexperienced with its mods.
Will check exhaust tomorrow in daylight but didn't notice anything out of the ordinary while I was under the hood and under the car.Thanks again
https://mbworld.org/forums/c32-amg-c...-misfires.html
The over boost fault is something you should normally only see while the pedal is on the floor. The fact it's doing it now may indicate a bad map sensor/harness.
Thank you both for your advice and suggestions, very much appreciated.
And that P108 comes with high boost, i have same issue. It must be some kind of program issue and EC try to fix my problem, but not succesful result...
Code comes somewhere over 1.3bar boost(it goes pending codes), and when it repeat several times then CEL goes on. I now have ~1.5bar max boost in those pulleys.
