Anyone here running OEM 16" CLK forged wheels?
Old Apr 30, 2014 | 05:30 PM
Capn's Avatar
03' CL600
I'm curious to hear from those who are running OEM 16" CLK forged wheels on all four corners (or if there's anyone crazy to enough to). I'm curious since the forged 16" CLK wheels can only fix a max tire size of 205 size and if you fit them with the sticky soft sticky tires would it be enough to compensate for stock wheels/tires? I'm curious to hear from the application of this in an C32.
Old Apr 30, 2014 | 05:38 PM
cm60k's Avatar
Are those CLK 16" Rims cleared the front C32 calipers...?, i think they are good with SLK32 isn't....??
ZAYED,,
Old Apr 30, 2014 | 06:02 PM
firstshadow's Avatar
03 C32 AMG
205 width tires on an AMG? Sounds like a death wish. Don't know if 16" wheels will clear the brakes, probably not.
Old Apr 30, 2014 | 06:14 PM
Capn's Avatar
03' CL600
W211 E55s run these wheels on the rear with spacers so not sure about the SLK32 calipers/rotors...
Old Apr 30, 2014 | 06:21 PM
cm60k's Avatar
Yes sure, 16" CLK Rims are great for less weight & tracks,
your Rotor is 330mm while C32 is 345mm,,
prefer if you can measure your front calipers & posted here, to compare them with C32's....
ZAYED,,
Old Apr 30, 2014 | 06:29 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
are you talking about the machined wheels that came on the 320 sport? also refereed to as "CLK light weights". I have a set that I am going to be putting on my W201 sportline. You can actual get these in an 8" width and run a 225 on them with no issues. I don't know about running them on a c32 but they will clear the 400e calipers.
Old Apr 30, 2014 | 06:35 PM
cm60k's Avatar
I think they will fit perfectly in 400E, cause it uses 295mm front Rotor...!
ZAYED,,
Old Apr 30, 2014 | 06:38 PM
Capn's Avatar
03' CL600
I never knew the CLK lightweights came in an 8" width, all I can find are the 7" width ones. Can you post a link where to find those 8" ones?
The SLK32/C32 wheels are front 7.5 and rear is 8.5 so having non-staggered setup would probably increase handling capabilities IMO.
Old Apr 30, 2014 | 07:00 PM
cm60k's Avatar
I didn't know they comes as 8", are they...??
ZAYED,,
Old May 4, 2014 | 02:50 AM
allenjdmb's Avatar
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
Forged?
With a few exceptions, I haven't seen a forged wheel on a Benz since he the good old days. From a 208? In a 16?mmmmm.
Old May 5, 2014 | 10:30 AM
insame1's Avatar
They are hard to find in the 8' width. It is a popular upgrade for the 190e's. You might check out the 190rev.net sight and see if there are any for sale.
Old May 5, 2014 | 05:37 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
Yup, these are forged, that's why they they're just over 13lbs.
