0-60 in 4.4 from a mostly stock slk32...
Old May 14, 2014 | 03:59 PM
Capn's Avatar
03' CL600
The slk32 subforum is dead so I thought I would post this here.
So 0-60 in 4.4 and granted gtech measurement is not 100% accurate but how 4.4 possible since stock is 4.8 seconds?
NOTE: I found out he has lightweight Konig wheels which are like 10 pounds lighter per corner!
Old May 14, 2014 | 06:59 PM
ghiaguy's Avatar
C55 AMG, 300D-T & Karmann Ghia
Nice! I say that modern, high-end tires helped here if that is accurate, not that tires were that different a decade or so ago. Aren't pulleys super easy to swap for more power also? 4.4 is quick!
Old May 14, 2014 | 07:14 PM
Capn's Avatar
03' CL600
This guy clearly states he only had resonator delete and green filters so its pretty much stock. I can understand modern tires helping but 4.4 is crazy
Old May 14, 2014 | 11:04 PM
ghiaguy's Avatar
res delete and green filters is nothing. Clearly, we aren't getting the whole story.
Old May 15, 2014 | 01:09 AM
C3Duece's Avatar
2002 C32AMG
those G-Techs aren't very accurate...probably closer to 4.8 for sure
Old May 15, 2014 | 01:52 AM
Capn's Avatar
03' CL600
100 pounds reduced (lighter wheels and resonator delete) is roughly equal to 15 horsepower and green filters added another 5 hp. Could it realistically improve it by 0.2 seconds so 0-60 in 4.6?
Old May 15, 2014 | 11:31 AM
C230 Mulac's Avatar
1999 E320 4matic Wagon, 2005 C55 AMG - sold, 1998 VW Jetta TDI - sold, 2006 C230 Sport - Totaled :(
One thing to keep in mind with the wheels: lighter wheels = lower moment of inertia.
10 lbs per wheel maybe drops 40 lbs off total weight of car, so doesn't really make a difference in that sense.
What makes a difference is it takes a lot less power from your engine to spin that wheel in one full revolution. That's probably the key to what's going on here, and this does make a pretty substantial difference in transferring the power from your engine to the road.
Next time you're working out at the gym, pick up a 5 lb weight and a 10 lb weight and try turning them in a circle and you'll understand what I'm getting at.
Engine power is constant so that doesn't change. Take the same amount of power to two circular objects, one is lighter than the other. The same power to the lighter object will make it spin much faster than the heavier object.
Sorry to be long-winded, but I'm trying to make it clear what I am saying.
Old May 15, 2014 | 11:34 AM
C230 Mulac's Avatar
This will help clarify: http://hyperphysics.phy-astr.gsu.edu/hbase/mi.html
Old May 15, 2014 | 09:12 PM
firstshadow's Avatar
03 C32 AMG
What helps a lot is that all of that weight was unsprung, so the effect is greater. Improved acceleration, improved handling, and improved braking. 10 lbs per corner is a HUGE difference!
Old May 16, 2014 | 10:22 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
I agree. I went from some Brabus knockoff 19s with crappy oversized tires to the 18" monlites with Bridgestone ps04 tires and the difference was noticeable.
