Help C55 not start
Old Sep 6, 2014 | 11:44 AM
pttk's Avatar
magLipVE
Help C55 not start
Hi, my C55 not start, introduce the key, the engine turns but not run.
wait a moment, try again and RUN, check engine is ON.
when I stop the engine, it sounds an alarm to remove the key.
Any idea?
Thank
Old Sep 6, 2014 | 02:31 PM
Quickvr4's Avatar
05 C55 AMG
Idea: Pull the codes.
Old Sep 6, 2014 | 04:40 PM
cm60k's Avatar
Could be CPS, it causes randomly bad starting.!,,
try to diagnose the car, codes will help..
ZAYED,,
Old Sep 6, 2014 | 04:43 PM
pttk's Avatar
magLipVE
Thank, Monday I see what codes
PTTK
Old Sep 8, 2014 | 11:31 AM
pttk's Avatar
magLipVE
P0335 Crankshaft Position Sensor A Circuit
I buy in Amazon
Thank
Old Sep 8, 2014 | 11:45 AM
cm60k's Avatar
Be sure to get OEM or Bosch only, don't take aftermarket, soo risky..
ZAYED,,
Old Sep 8, 2014 | 11:51 AM
pttk's Avatar
magLipVE
Amazon.com: Mercedes-Benz Engine Crankshaft Crank Position Sensor Bosch OEM 0261210170: Automotive Amazon.com: Mercedes-Benz Engine Crankshaft Crank Position Sensor Bosch OEM 0261210170: Automotive
Original part
Thank
Old Sep 8, 2014 | 12:27 PM
cm60k's Avatar
There are 2 types of Bocsh/OEM crank sensors,
*one comes with 1 Pin connector,
*one comes with 2 pins connector,
Name:  CPS 2 pin.JPG
which one you have..?
ZAYED,,
Old Sep 8, 2014 | 12:31 PM
pttk's Avatar
magLipVE
This
is compatible with my 2006 C55 AMG, in Manufacturer Part Number detail : C55 AMG / 2000 2001 2002 2003 2004 2005 2006
Old Sep 8, 2014 | 01:41 PM
ghiaguy's Avatar
C55 AMG, 300D-T & Karmann Ghia
Nice, glad you got off with only the CPS! Let us know when you are back on the road
Old Sep 8, 2014 | 01:47 PM
pttk's Avatar
magLipVE
Very happy and waiting for the sensor to install and go eat the road
Thank
Old Sep 17, 2014 | 12:15 PM
pttk's Avatar
magLipVE
Everthing is ok NOW, but it was not easy, 4 hours to remove the sensor from below, from above was impossible, no space.
After getting the exhaust system had access to the sensor.
Finally scan fails to remove
Thank to all
Old Sep 19, 2014 | 10:28 AM
C230 Mulac's Avatar
1999 E320 4matic Wagon, 2005 C55 AMG - sold, 1998 VW Jetta TDI - sold, 2006 C230 Sport - Totaled :(
Holy crap you removed the entire exhaust to get up and install the sensor?! Man, I commend you for doing all that. I got mine from the top with a long extension around the back ignition coil on driver's side, just unbolted it to move out of the way. If you remove the MAF you can get it from the top.
Good to see it's done though!
