Dealer replaced valve cover gaskets, now idle issues.
Old Nov 9, 2014 | 12:11 PM
trbo2nr's Avatar
2004 C32, 2006 Honda CBR1000RR, 2007 Harley NightRod, 2013 Harley Road Glide Custom
Question Dealer replaced valve cover gaskets, now idle issues.
I had my local dealer replace the valve cover gaskets the other day. Yesterday, my gas cap warning indicator lit up (never seen this in eight years of ownership). Along with that warning, I noticed the car appear to hunt for idle and often cycles from 1800-2200 (up and down).
I found a like condition on the E55 AMG forum and someone mentioned a vacuum leak. The problem is, I can't find it. Car never had this issue unitl after the dealer did the valve gasket replacement.
Any idea? Yeah, I noticed the air breather covers weren't all snug and have since tightened.
Bob
Old Nov 9, 2014 | 02:14 PM
2MCHCAR's Avatar
Supercharged CLK500,ML500,S580
Bob
I have a M113 V8 and I experienced a similar situation when my valve cover gaskets were replaced. It ended up being the driver side breather hose that went from the driver side valve cover to the maf. It had a big crack that let in a lot of air. These hoses get brittle over time so it's not unusual that they break when disturbed.
Old Nov 9, 2014 | 02:19 PM
trbo2nr's Avatar
I thought I checked that hose, but will double check once the car cools down. Thanks for the reply.
Bob
Old Nov 10, 2014 | 07:14 AM
C230 Mulac's Avatar
1999 E320 4matic Wagon, 2005 C55 AMG - sold, 1998 VW Jetta TDI - sold, 2006 C230 Sport - Totaled :(
When I did the valve cover gaskets I also replaced all of those breather hoses. It's recommended b/c of what 2MH said, they get brittle and when you pull them off to take the valve covers off they will likely break. Even if they don't, there may be some cracks that you didn't see when you did it (or the dealer did it). I'm assuming they probably didn't replace those hoses for you.
I also just noticed you were in Bristow. You should get up with us for our monthly meets! Look for the thread "Dinner Meet Rockville MD" and find us.
Old Nov 10, 2014 | 07:31 AM
trbo2nr's Avatar
Will do. This week is tough for me to get replacements as I am in training, but will look into replacing them. Thanks. I will check out the link to Dinner Meet Rockville MD too.
Bob
Old Nov 10, 2014 | 07:34 AM
C230 Mulac's Avatar
I'll just make it easy for ya: https://mbworld.org/forums/c32-amg-c...ille-md-3.html
If you ever need help with repairs, let me or any of the other guys around here know. We do all our own work and it saves quite a large chunk of $$$$ to not go to the stealership.
Old Nov 10, 2014 | 07:35 AM
C230 Mulac's Avatar
Also, this: https://www.facebook.com/groups/5174...841/?ref=br_tf
Old Nov 10, 2014 | 11:14 AM
raphman's Avatar
'16 C63s
I wish I still lived in MoCo... I miss it =( if ever I'm up there when you guys are having a meet, I'll def do my best to show up!
Old Nov 11, 2014 | 12:38 AM
JonMBZ's Avatar
06 C55, 09 E350
where I work we always replace all the breather hoses when doing valve covers
Old Nov 11, 2014 | 06:08 PM
trbo2nr's Avatar
The passenger side breather hose underneath the box had a chuck taken out of it. I used a mirror and flashlight and looks to be at fault. Odd thing is, car ran fine before the valve cover gaskets were replaced. It almost looks like it was crimped.
So, it will run like crap until I can have the dealer fix it (in training all week and can't even get the part and do it myself). I could send the Mrs to the shop, but I rather not.
Thanks again for all the replies and PMs.
Bob
Old Nov 14, 2014 | 06:28 PM
trbo2nr's Avatar
Did not see anything odd, but cleaned dirty throttle body, and code3 filter...
I also checked all the hoses and all is good. I will test drive this weekend. If I recall, the CEL comes on with the GAS CAP warning, and then low fuel after 30-minutes of driving..
