Could be fuel pump c32 2001
2. If fuel pressure is not correct
3a. Replace fuel pump (OEM) or with Walbro 255
3b. Replace fuel filter (OEM or some equivalent after market product)
Fuel pressure gauge will help a lot while adding mods. If you are actually going to make 500/500+ HP then you need to big up fuel lines as others have already advised.
You are always told to install a wideband AFR gauge when modding a car. Equally important is fuel pressure gauge. It will instantly tell you if there is a problem with fuel lines, pump or filter/regulator.
However, on the dyno, I ran slightly lean at the top of 4th gear and he said that larger injectors would help that.
he recommended me to this place:
http://www.fiveomotorsport.com/
The power will come with Jerry tune. He is a gentleman and wants what you want. "speed"
