FutureAMGxx's C55 Build Thread
This is the one out of the c32 setup (probably exactly the same). My kit is from Needswings, but you could probably find some universal filters similar to them on ebay or something. I like the Needswings kit better than a diy kit because they include replacement pieces all the way down to the throttlebody. Making it wider/less restrictive all the way past the MAF!
I think I will get some of these when the time comes. The main hp gains are to get rid of the extremely restrictive stock flange at the end of the stock headers. This will do that nicely. The guy at the shop showed me some beautiful 4-1 merge collectors with perfect taper point etc but the extra 3hp really isn't worth another $2k. I am sure you will let us know how you find them.
Btw... Op has a nice car!
A month or two ago at 76,350 I replaced the idler and tensioner pullies and the belt. The tensioner developed a small squeak.
I also replaced the engine and cabin air filters. All parts from fcpeuro, lifetime warranty!
At the same time I went ahead and and put on new strut tops and new sway bar end links!
Are these the B16 PSS9 with the electric suspension system? If so, what's the part #? Tire Rack shows Part# 48-088602 but the website picture is different than what you installed. Also, did you leave the ride height per oem specs or did you lower the ride height?
Thanks...
Rob
Thanks...
Rob
Here's the url which shows the pic for the Bilstein B16 Electronic Suspension System for a C Class. Then you can choose an option for the C55 and your install pics match that strut/shock system. https://www.autoanything.com/suspens...pension-system
Rob
Can you share the price you paid for the B16 PSS9's? You can pm me.....The best price I found today was $1,547.70 to my front door. The guy gave me a Veteran's discount....
Thanks...
Rob
I had been watching them for a year or so and I purchased them last fall when they got marked down like 3% so it was something like 1450 plus tax or so.
