Square stance
Old Mar 21, 2016 | 11:54 AM
Morphh's Avatar
C32 amg
Square stance
Has anyone put own rear wheels on the front of cars for a square stance? Will it work?
Old Mar 21, 2016 | 01:12 PM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
They won't clear the calipers on a C55. Rears are too concave.
Old Mar 21, 2016 | 01:48 PM
sweet jones's Avatar
W209, E46 M3 (dead), S54 swapped E46 Touring
yes it will work, you just need to add a spacer up front for the calipers and inner wheel well to clear. I converted my wheel bolts to wheel studs and lug nuts to make the process easier as well. I used a 15mm spacer but you could test fit to see what works best for you.
Attached Thumbnails Square stance-low-clk.jpg   Square stance-clk-rolling.jpg   Square stance-clk-rear.jpg
Old Mar 21, 2016 | 04:31 PM
Morphh's Avatar
C32 amg
Looks good thanks for inputs
Old Mar 21, 2016 | 05:41 PM
Correct, spacers, and probably not much of one, and you're golden. Just trying to bolt them up is a no-go, is what I meant.
Old Mar 22, 2016 | 03:05 AM
Khan 55's Avatar
2004 CLK55 AMG W209
your set up is gorgeous man. Maybe I will look into it in the distant future when I maybe become a show stopper. As for now I am happy with the way my car is with the stock however I would prefer the all round stepped 55 wheels. The rears do look better than the front.
Old Mar 24, 2016 | 04:11 PM
sick430's Avatar
CLK Cabrio
I am running a square 17x8.5 on my CLK with c55 front calipers.
Old Mar 24, 2016 | 05:13 PM
///AchMeinGott's Avatar
none... for now
Before anyone says yes, I did it, you have to compare the C55 rear wheel offset to whatever wheel you have. Obviously spacers usually greatly open the door of possibilities though.
Old Mar 25, 2016 | 01:25 PM
Morphh's Avatar
C32 amg
Sick430 u have any pics u using any spacers?
Old Mar 25, 2016 | 07:55 PM
sick430's Avatar
CLK Cabrio
The 18's show the calipers as you cant really see them I the other shot. the bottom is the square track setup 17 X 8.5 with 30mm offset
