C55 brake squealing please help
pads face looks harmed with Rotor groove lines,,
i think you need to replace the Rotors & Pads in the same time, that will definitely save time & helps a lot..!!
ZAYED,,
It really is dealers choice on the matter. I have found that certain setups work better together than others. There is a lot of difference between manufactures/models of pads a rotors in regards to their materials. you can run into issues of a pad that is so hard you go through rotors like crazy or they make noise no matter what you do. After all the setups I have run on all my cars I have found that stock is usually the most problem free DD setup you can buy.
Essentially there's a lot of things that can cause vibration, your best bet is to search the forum and try to figure how exactly when the vibration is happening, at what speeds and what it feels like.. Pulsating, slight vibration, thudding.. Etc
Or it could be a wheel out of balance a bad tire or a million other things. We could speculate all day but with the responses from the OP in the thread I would suggest he go to the dealer and get a PPI.
