Anyone replace Bose speakers with aftermarket?
Old Mar 4, 2004 | 10:23 AM
kushal's Avatar
How does the setup on the Bose system work?
Has anyone replaced the speakers and amps while keeping the headunit? How about just the speakers?
Subs: aftermarket sub to add to the stock system. Anyone try this?
Old Mar 4, 2004 | 01:21 PM
LorinserCClass's Avatar
The True OG Modded out W203
Re: Anyone replace Bose speakers with aftermarket?
Ive done the last 2. Sounded VERY good but not GREAT. Ended up switching to an Alpine D900.
Old Mar 4, 2004 | 04:36 PM
kushal's Avatar
What was your setup?
What did you install? Where did you install the subs, did you use custom enclosures that form fit into the trunk or just a box?
How do you think the wheel well would be for a sub? I have a 2002 with no spare, so that space it totally open.
Old Mar 4, 2004 | 04:52 PM
Re: What was your setup?
MBQuartz components, 2 JL Audio W6v2 12"subs, 2 Phoenix Gold Titanium amp and 10 farat cap and the ICE. The subs sit in the trunk....I guess you can say I had them put in custom enclosures:p
Old Mar 4, 2004 | 11:42 PM
cosc32's Avatar
c32
I added a sub box in my trunk. Boston Acoustics 12", Xtant sub amp. I connected to the high level signal going to the rear door speakers. It isn't great, but it is much, much better than stock. I couldn't stand the stock sub on rock or blues. If I did it again, I would just use a 10" sub, and get a more powerful amp.
Old Mar 7, 2004 | 03:08 AM
sicc-made-c32's Avatar
does anyone have a system with their navigation?
and how does it sound?
Old Mar 7, 2004 | 12:32 PM
Bux's Avatar
Bux
G
im about to do it within a couple days..anything will sound better than stock anyway
Old Mar 7, 2004 | 11:44 PM
That's the only reason why I wouldn't get navigation. My bumps will sound like ****..id rather get the kenwood flip up, and just add navi to it. Plus my interiors speakers would be hella clean (aftermarket) whatcha think?
Old Mar 8, 2004 | 03:14 AM
Dink's Avatar
2002 C32
i have my sub in the spare tire area. i think i got a 12'' in there. make sure you get the spare tire well dynomatted if you are gonna do that. it rattles like a *****.
Old Mar 8, 2004 | 06:28 AM
N.M.M.'s Avatar
I have subs in my car, and I have command. It is some tricky wireing but it sounds pretty good. If you do a search I think I posted the how to. (a long time ago)
