E55 swap
Old Sep 26, 2016 | 02:46 PM
GTibunny8v's Avatar
2005 C55
E55 swap
Who here has done one? I've talked to Eurocharged and was told I'd need a Star in developers mode to code the M.E. after they unlocked it. I can handle the mechanical and electrical portion of the swap. I need to know what exactly is needed to code the M.E. so I won't have any issues with the other systems in the car.
Thanks in advance
Old Sep 26, 2016 | 03:27 PM
Morphh's Avatar
C32 amg
Thanks in advance
i know someone on you tube did it
winks911's Avatar
2006 C55 RENNtech
I'm meeting up with one member who has done the swap, there was another one done Can't remember where but it was C55T
I myself has done the RENNtech build.
If I didn't purchase all the RENNtech parts, I would have done this.
But for the prices of E55 today,
One has to ask if this swap is worth doing?
Old Sep 26, 2016 | 08:20 PM
tw2's Avatar
tw2
A member did it with a C32, thread on this forum. C32kompressor did it to a w209 CLK55, thread in the CLK55 forum.
Old Sep 30, 2016 | 02:09 PM
93Corrado's Avatar
'05 C230 SS, '94 E420 (RIP), '05 C55
Thanks in advance
If you're on Facebook there's a C55 group page https://www.facebook.com/groups/c55amg/. A member there from Indiana just posted pictures of his E55 swap into a C-Class wagon. The wagon looked to have had an M113 already in it. I'm not sure if he had swapped that in previously or if it was a true C55 that was imported. Join the group and hit him up with questions.
Old Nov 18, 2016 | 07:41 AM
alfred dahdah's Avatar
w 203 c 55 amg
i did this swap years ago!!
I did the swap of m113k on my c55, its a bit expensive but its also worth it
Old Nov 20, 2016 | 07:46 PM
GTibunny8v's Avatar
2005 C55
I ended up getting a 60k mile S55 engine, harness, and ECU. Needed to swap oil pan and pump from the original engine. Also needed to swap a the wires to fit my front SAM, add the second wire for the alternator (the S55 used a 1 pin regulator and the C55 used a two pin. I used the stock alternator.), the S55 rear oxygen sensors are part of the body harness. Needed to remove the rear oxygen sensors from the C55 harness and retrofit it to the S55 harness. The biggest concern is the fuel system. The factory pump and regulator in the tank is good for 3.8bar with no easy way of upping the pressure to the 5.2bar the M113k needs, we are still sorting that out. Looks like a larger fuel pump and internally regulated fuel filter. The guys doing the swap came up with custom machined AN fittings for the oil cooler lines and a cooler installed in the passenger side of the bumper. Hoping to have everything done and running by the end of this week.
Old Nov 20, 2016 | 08:46 PM
MrMustard's Avatar
C55 AMG
What did you do about coding the ecu to your vin so keys work, etc.? I'm guessing a knowledgeable star programmer. As for a fuel pump, that's pretty common for engine swaps. Get a manual fuel pressure regulator with fittings to the fuel rail and you should be good.
Old Nov 21, 2016 | 07:38 AM
Khan 55's Avatar
2004 CLK55 AMG W209
Congrats on getting pass the half way mark. Atleast you almost there now. Please share more information with us as many are taking this avenue now.
Old Nov 21, 2016 | 07:43 AM
GTibunny8v's Avatar
2005 C55
I had Eurocharged do the VIN swap for me. I just need to modify the SCN string for a C class. We thought about a manual FPR at the rail but the regulator on the filter assy in the tank would still regulate the pressure to 3.8 bar. I was also worried the factory filter assy would not flow enough fuel for the future mods.
Old Dec 3, 2016 | 04:10 PM
GTibunny8v's Avatar
2005 C55
Got the heat exchanger installed and pump mounted with a separate reservoir tank. Also had the custom AN oil cooler fittings for the engine and oil cooler installed. Got the fuel system finished also. Had to swap to an external fuel filter sender unit for the drivers side of the tank. Installed the walbro pump and used an Audi S6 fuel filter with an internal regulator to get the 80 psi of pressure the M113k uses. Still waiting on the Star in developer mode to get this thing running.
Old Dec 5, 2016 | 08:37 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
doesn't the e55 fuel pump assembly fit in the c55?
Old Dec 5, 2016 | 10:52 AM
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
I'm in love with this thread.
Old Dec 5, 2016 | 06:26 PM
GTibunny8v's Avatar
2005 C55
It's close to $1000 for the E55 setup. This cost was 1/4 the cost.
Old Feb 2, 2017 | 04:52 PM
EVOII_Racer's Avatar
Mercedes Evo II
Amazing car well done
To answer yes the swap is worth it and strongly thinking about it!
Why ? The c55 is much smaller and nimbler than the e55 and also lighter no reason why not to do it
Old May 21, 2017 | 09:16 PM
GTibunny8v's Avatar
2005 C55
Old May 21, 2017 | 09:27 PM
cm60k's Avatar
Really Awesome, goooooood joooooob..
-;ZAYED;-
Old May 22, 2017 | 02:32 AM
tw2's Avatar
tw2
Congratulations, fantastic work. I took the easy, cheaper but much less exciting way out and bought an E55.
Old May 22, 2017 | 12:25 PM
WaveyKat's Avatar
Something Slow
nice!!!
Old May 25, 2017 | 08:24 AM
Khan 55's Avatar
2004 CLK55 AMG W209
Cudos to you man. So you mentioned Eurocharge do the ECU flashing for the VIN. What they charge you?
Old May 22, 2019 | 10:46 AM
ctravis595's Avatar
2002 CL500 to CL55 conversion
how is this car running today? i was pleasantly surprised to find good compression numbers on my 55 n/a swap engine i did. now im thinking of adding a m113k supercharger with a large(?) pulley for low boost, 5 or 6 psi, nothing crazy. i know my y car came with ME2.8 so perhaps this is possible to be programmed on my existing ECU with some star developer trickery
Old May 22, 2019 | 08:30 PM
Morphh's Avatar
C32 amg
Awesome man can u put a pic of the separate ic reservoir u used?
Old Sep 2, 2019 | 06:00 PM
Lukesportsman's Avatar
C55, SL55
These always seem to fizzle out as threads with so few coming back as finished projects sadly.
Old Sep 3, 2019 | 12:17 AM
ctravis595's Avatar
follow my thead in the w215 section, i've been running my n/a 55 m113 swap for years, and i'm just finishing the turbo build. apparently this will be considerably faster than stock m113k cars, as long as everything goes smoothly with the install
Old Sep 3, 2019 | 07:54 PM
insame1's Avatar
Got a link to the thread?
