SL 2-Piece Wheels
Old May 1, 2017 | 11:47 AM
93Corrado's Avatar
'05 C230 SS, '94 E420 (RIP), '05 C55
SL 2-Piece Wheels
Is anyone running these 19" 2-piece spilt spoke AMG wheels to fit on a C55? I PM'd Swedepat but it doesn't look like he's been active on the forum in a few months. I'm only finding these wheels in the correct offset for our cars from a SL65. EPC isn't showing a part number for these on a SL55, just a SL65. The SL65 wheels won't slide all the way onto the C55 hub. The center bore of the wheel seems to be a bit too small. Also I'm wondering if there is enough depth in the center bore to accommodate the cap for the wheel bearing. I have RAD lug bolts on order.
Originally Posted by swedepat
These are real SL55 split rims 8.5" and 9.5" diam 19"
ET30 and 31
Now equipped with Vredestein Ultrac vorti R 235/35 and 255/30
Old May 1, 2017 | 05:24 PM
Morphh's Avatar
C32 amg
Nice looking wheels
Old May 1, 2017 | 06:04 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
Mercedes hubs should all be the same (of that vintage year), push harder.
Old May 1, 2017 | 08:16 PM
cm60k's Avatar
These nice Rims sharing the same center bore with C55, which is (66.6mm),,
MB part #:-
*Fronts: "211 400 12 02", (8.5Jx19) ET30
*Rears: "211 400 14 02", (9.5Jx19) ET31
-;ZAYED;-
Old May 4, 2017 | 01:25 AM
Chest Rockwell's Avatar
Veteran: Navy
2005 E500 4matic wagon, 2006 AMG E55, 2009 Smart Fortwo
I've been running SL55 wheels on my '06 C55 for a few months now. I have to use a spacer up front to clear the calipers, but the rear fits fine.
Old May 4, 2017 | 02:14 AM
Tom Sunday's Avatar
2003 SL500 Base
Will they fit: 2003 SL500 Base with SL55 AMG Wheels?
WOW...Fantastic looking rims. I have been running 18" staggered stock rims on my 2003 SL500 and always wanted to purchase these specific 19" AMG rims as an upgrade. But over the past months having had no real success at in finding any qualified sources (vendors) for purchasing a set of these. Besides I am not sure if a 2003 SL500 will easily accommodate a 19" rim fitment and also if these type of AMG rims designed for a later SL55 model year will actually fit? Particulary on the front! 10mm spacers or more? Any help and or advise on the AMG rim fitment subject is welcome!
Old May 4, 2017 | 11:28 AM
93Corrado's Avatar
Thanks for the info. The wheels I have have different part numbers and different offsets. The part numbers are A211 400 1202 with an ET of 30 and A211 400 1402 with an ET of 31.
I just had them refinished and the centers powder coated so maybe that's why they're not fitting on the hub. The lug bolts should be here on Friday so I'll try to get them on the car over the weekend.
Old May 4, 2017 | 03:36 PM
Veteran: Navy
If you ever end up in the Seattle area with time to kill, stop on by and we can see if these wheels will fit your SL500.
Old May 7, 2017 | 02:43 PM
Veteran: Navy
Came across this ad recently trying to find another pair of Brabus wheels to finish my set. Sure look good on that W211.
Old May 9, 2017 | 09:04 AM
93Corrado's Avatar
I finally had some time yesterday to give it another shot with the install. You guys were right, they fit after I cleaned up the hubs a bit with a wire wheel. Applied a bit of anti-seize to the hubs and bolted them on. It was a very snug fit but they're on. No spacers required to clear the front brakes. Thank you all for the technical advice!
Old May 9, 2017 | 09:08 AM
Veteran: Navy
Looks great!
