HOW TO: Replace c55 spotlight the easy way
Old Jun 5, 2017 | 10:42 PM
daynger's Avatar
C55 AMG
Righto, once again there is a major lack of how to fix your own basic stuff on the c55 online, so here is another one.
The driving lights are quite low and are very vulnerable to getting smashed, like mine did.
HOW TO: Replace c55 spotlight the easy way-20170605_115335_zpsxgjsjwj1.jpg
The consensus seems to be you need to take it all apart from behind and underneath, taking off various underpanels and other things, that is a load of bollocks, this is easy to do with basic tools and took me about a half hour figuring it out as i went.
First step is to get yourself a replacement Hella unit, use the internet as price varies alot, i got mine form Ebay US.
HOW TO: Replace c55 spotlight the easy way-20170605_121420_zpswxqqfzdx.jpg
Next you need to get the grille piece out, its held in by four clips that release by pushing a holder leg up (at the top) or down (on the bottom) with a screwdriver and pulling the grille towards you, the easiest place to start is the top outside edge.
This is a clip here.
HOW TO: Replace c55 spotlight the easy way-20170605_115744_zpsjtpvkezs.jpg
Once you work the grille out just let it hang on the wiring for whatever sensor that is, dont yank it any further than needed.
HOW TO: Replace c55 spotlight the easy way-20170605_115738_zpszddokltd.jpg
Now you can see the four torx screws that hold it in place, undo those screws obviously. The bottom inside screw will be to a metal plate that is clipped to the bumper, just turn it out of the way, it turns freely.
You will then be left with the light just hanging around like this
HOW TO: Replace c55 spotlight the easy way-20170605_121646_zpsfmu9gsxg.jpg
You need to make sure the adjuster screw at the bottom is tucked down behind the front bumper plastic, then push the upper plastic up with your hand as you pull the top edge out first, i highly recommend using a cloth or rag to avoid damaging paint as the spotlight bracket scrapes along the top edge a bit. I didnt on the way out but did on the way in with the new one, i marked it a little but not in a noticeable spot and only if you are too close not to be getting run over.
HOW TO: Replace c55 spotlight the easy way-20170605_121626_zpscw9n88fl.jpg
Now the whole unit should be hanging out on its wiring, there is a rubber seal on the back that needs working off (mine was cable tied on???), then you can unplug the lamp and the whole assembly falls away.
HOW TO: Replace c55 spotlight the easy way-20170605_121321_zps7u7jlfjp.jpg
Next adjust the new unit to be on the same angle as the unit you just removed via the adjustment screw.
Mine out of the box was a bit different.
HOW TO: Replace c55 spotlight the easy way-20170605_121112_zpsmr8i0cnx.jpg
Now it is just plugging in the lamp, reinstalling the rubber seal and getting the light back in place, definitely use a rag for this otherwise it will murder your bumper paint.
Screw the light back in with the four screws, test the light works then clip the grille back in and admire the few hundred dollars you just saved.
HOW TO: Replace c55 spotlight the easy way-20170605_122106_zpsol8zrexw.jpg
Too easy.
Old Jun 6, 2017 | 12:05 PM
PJmak's Avatar
Awesome. I have one cracked.
How much is the part??
Old Jun 6, 2017 | 04:04 PM
busta55's Avatar
'04 C55 AMG
daynger, Great post!
PJmak:
http://www.ebay.com/itm/NEW-Mercedes...RYWnvO&vxp=mtr
http://www.ebay.com/itm/Mercedes-2x-...lV8tef&vxp=mtr
Old Jun 6, 2017 | 04:56 PM
PJmak's Avatar
Ebay blocked at work, will have to check at home
Old Jun 7, 2017 | 02:33 AM
Khan 55's Avatar
2004 CLK55 AMG W209
That my friend is a swell way of doing it. I get to it the same method. The sensor is called the outside air temp sensor that displays on the dash the temperature.
Old Jun 7, 2017 | 09:37 PM
RenC55AMG's Avatar
2005 C55 AMG
The replacement is $55 at the dealer. And that connection hanging from your mesh surround is your outside temperature sensor.
Old Dec 10, 2018 | 05:57 PM
PSB's Avatar
PSB
Thanks Guys... needed this info..
Old Dec 11, 2018 | 12:38 PM
norcalcasey's Avatar
2006 C55, 2004 ML350
Hope someone can help here. I bought a C55 a few months back that was missing the foglights and mounting brackers. Ordered them both (brackers from dealer and fogs from FCP euro) and installed them but for some reason the connectors at the bulb aren't the same. I assume just buy new bulbs rather than re-do the wiring harness. Anyone else run into this problem?
