C32 new alt, Not Charging, Hidden Fuse
In my case it turned out that My passenger seat was draining my battery and alternator somehow. After disconnecting the power module to the passenger and replaced with new battery car worked fine. Like I stated before this May or May NOT be the case with your situation but I just thought I should throw it out there as a possibility.
According to what I found there, most models of the W203 have a 175 amp fuse (f56) (somewhere) in the cable running from the ALT to the starter (oddly, no fuse shown on M113 models). Normally the "star finder" in the ETM will show you a picture of the actual location of a component (f56 in this case) but oddly, in this instance it merely says "image not available" and "F56
Starter, alternator fuse (in wiring harness)"
I suspect that you can check it by testing for continuity between the connection at the alt and the connection at the starter (you will likely want to remove one end while you do this check to eliminate the possibility of getting a misleading continuity reading through the ground-path).
hope that helps,
Chris
good luck,
Chris
I just had this same issue. Turned out to be a non-serviceable diode within the alternator. If you have continuity between the alternator lead and the positive cable of your battery, then you do not have a fusing issue. To my knowledge, the only large fuses on our cars are the ones that reside in the x4/10 unit right by the battery (black box with (+) tab on it for battery charging.
At fist I just replaced my voltage regulator, thinking worn out brushes were the issue, but I was sorely disappointed when I found out I needed a new alternator.
The new alternator did however solve my issue.
Hope this helps!
Nick
New alternator and now it cranks no start. How do I check the fuses in the prefuse box and know if they are blown or not? I have opened it and see the cables.
Theres very little rust it looks like on some but very little. Little specks of rust. Im pretty sure I have the same issue and need to replace my ground wire.
