M44 error code
Recently i came across a C30 that i aquiered and working on to restore it.
I have managed to fix almost all the issues with the car. The only issue i am struggling with is an error i get for the air circulation pump.
The error code is P2519-008 M44 (Charge air cooler circulation pump) open circuit.
Any help will be much appreciated.
Thanks in advance.
Thanks in advance.
hope that helps,
Chris
hope that helps,
Chris
also found a schmatic of the intercooling system and will try and see if i can locate the pump this weekend. Will keep your advice in mind when working on it
this is the current direct replacement for M44 in the SLK32 and C32 (also used in e55, sl55,s55, etc)... it is often referred to as the "010" pump the part number ends with 010 (original pump ended with 002 IIRC)
not sure if the c30 uses the same kind of charge cooler pump (as the slk32 and c32 ) ... but if it does, this is the current pump that Mercedes sells for this application (under part number A0005000286)
hope that helps,
Chris
HOWEVER, the pump is a bit different than the standard bosch. The pump referrenced in the EPC for the C30 (model # 203018) is a Pierburg with a mercedes part number of 0005505583
SO, does your c30 have n air-to-air OR an an air-to-water intercooler? AND if it does have the air-to-water , is it on the left or right of the car (relative to sitting in the car and looking forward)?
I wont say the CWA100 would not work, but if you don't need (or use) its PWM control ... a $110 bosch should do the job
if you do need the CWA100, best to buy it under that part number (about $300 vs 2 - 4 times as much under mercedes part number)
And it is very similar to Pierburg CWA 100.2.
But I would like to make sure if that is correct one (Pierburg CWA 100.2) and will work with c30 engine, as it is not cheap = /
https://www.ebay.com/itm/Water-Pump-...UAAOSwR8hdvCCN
