C55 oil dipstick
local MB said there's nothing for the C55. Does the C63 dipstick work ??
Cheers for any advice ..
regards
I don't understand why.
Do you read on the manual dipstick the 165 mm?
When reading the OBD the car must be absolutely levelled.
1. Can I use a Topsider to suck oil up through dip stick tube in C55?
2. In understand C63 dipstick fits C55. Can I leave it in while driving or is it simply a measurement tool. I would like to be able to see the oil when measuring.
2. No. The correct dipstick will not fit all the way in and the reading should be 165mm.
If you drain both plugs, 9 qts will be correct.
