Oil leaking from where? Oil cooler?
Old Apr 18, 2018 | 10:59 PM
Nick Janssen's Avatar
2005 C55, BMW 335d M-Sport
I'm having oil leak out of my oil fill cap but I've already replaced the cap. I think i have a slow leak from around the oil cooler gaskets and possibly the oil filter housing itself. I tried cleaning it away to see where it's coming from but that's turning out to be harder than expected. I bought the oil cooler gaskets but are there others I should replace while I'm in there? The bottom of the power steering reservoir has oil on it as well and the back of the AC compressor has oil on it that's leaking from above. None of this is coming from the valve covers gaskets. Those have been replaced within the last couple years.
residue under CCV gasket
residue around and under cap
Old Apr 19, 2018 | 05:30 AM
KJI3jflarryfe93's Avatar
did yo buy all 3 gaskets for oil cooler?
Old Apr 19, 2018 | 08:55 AM
I've got the two smaller gaskets. Is the big one for the bottom of the oil filter housing?
Old Apr 19, 2018 | 09:42 AM
jawohl, das ist richtig
clean around sides and @ the bottom of the öl filter housing then keep an eye on öil leaks.
start your car let it idle and look for leaks.
when you drive, from wind pressure öil will move to different locations.
your car is it a high mileage car?
over time gaskets going bad with leaks, you don't know which one is going bad, might as well replace all 3 of them to be on the safe side.
Old Apr 19, 2018 | 09:53 AM
That's what I'm thinking. While I'm in there I'd rather do all of them. The car has 117k on it. I was just wondering if there could be another issue causing the oil to backup out of the fill cap. I read somewhere this could be caused by CCV blockage. Is this true?
Old Apr 19, 2018 | 10:12 AM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
I'm betting the oil cooler gaskets. I just did this myself..twice.
The easy way is to remove the oil filter housing and cooler as a unit, then swap the 2 smaller gaskets to the cooler.
The hard part is you need a really big special socket to pull the oil filter housing. I forget the size, but it's like 46mm.
The 1st time I did the oil cooler only. What a pain to work in the tight spaces!
It still leaked, so I bought the big socket and replaced the 2 smalls and the big filter ring gasket.
I also put a very thin film of RTV sealant on the gaskets (against the WIS and everyone here). This time it worked. Your mileage may vary.
Like this: http://www.benzworld.org/forums/w163...il-cooler.html
Old Apr 19, 2018 | 11:28 AM
PJmak's Avatar
Its leaking from here for sure. Very common. Do your oil cooler gaskets while at it too.
Old Apr 23, 2018 | 12:51 PM
PJmak, what is it that you circled? That isn't where the cooler gaskets are or the filter housing gasket. I just resealed the breather covers this weekend. That should help a little.
Old Apr 23, 2018 | 01:06 PM
PJmak's Avatar
is a timing case cover gasket.
Very easy to do and very cheap.
Its separate from the oil cooler seals.
Old Apr 23, 2018 | 01:15 PM
Good to know. while I have the timing cover off, is there any other maintenance that needs to be done in there? Chain tensioners, etc? For the first few seconds on startup it sounds light a slight ticking noise from the front that always goes away. It lasts for about 15 seconds. I assume I'll need to take the power steering pump off to get to the timing gasket?
Old Apr 23, 2018 | 01:31 PM
PJmak's Avatar
Thats usually the MOT valve.
You can find it here.
Listen closely if thats whats ticking. Pretty normal from what I heard.
Not sure about what needs maintenance when it comes to timing chain. Havent done one ever
Old Apr 23, 2018 | 01:32 PM
PJmak's Avatar
You dont have to take anything off to redo that little gasket btw. I did mine pretty easily. Its a little tight with the m113, m112 theres way more room
