My 2007 Mercedes-Benz cls550 does not crank when engine is hot
I can test battery from the Starter relay. I can measure voltage at the input of the Starter relay.
What is a problem?
Johnny
(W219) engine
1. Engine circuit relay
2. Starter relay
3. Circuit relay
The engine circuit and starter relays are controlled or turned on by 2 signals from the ME control module.
The circuit relay is controlled by the ignition key. These 3 relays reside in the Driver Side SAM control module.
I will check them on this weekend.
Johnny
2. Starter relay
3. Circuit relay
Johnny
I find out from the Starter relay. The Starter relay has input voltage of 12V (Pin 3) and 12V (Pin 1 and 2) to close connection but its output (Pin 5) is 0V. The output should be 12V. The output is connected to the starter solenoid. I measure resistance to be 0.2 Ohm between the output and ground when engine is hot.
