360mm rotors part #
Subscribe
Aug 14, 2018 | 12:17 PM
I have a c32 that I swapped out the brembo 8 piston calipers and need the 360mm rotors. The sl65 that donated the calipers rotors are too deep to fit correctly so need the depth to be 47mm and the dia 360mm. Any ideas? Did they make a p030 package for the c55 that had 360mm rotors with the correct specs to fit our c32/55 hubs?
Reply 0
Aug 14, 2018 | 05:25 PM
Do you want to go with 1-piece or 2-piece Rotors..?
-;ZAYED;-
Reply 0
Aug 14, 2018 | 05:30 PM
1 piece
Reply 0
Aug 14, 2018 | 06:06 PM
You can go with 1-piece (360mm) Rotors from "W218 Cls500",
the offset is (51mm),,
they will fit, but as i remember; need (5 or 6mm) washers between caliper bracket & spindle, to balanced the Rotor correctly..!
-;ZAYED;-
Reply 0
Aug 14, 2018 | 06:55 PM
Thank you
Reply 0
Aug 18, 2018 | 07:23 PM
The only rotors I can find for that application CLS500 are 330mm and not the 360mm I need to complete the upgrade
Reply 0
Aug 18, 2018 | 11:27 PM
Try a 2012 and newer CLS550.
Reply 1
Aug 20, 2018 | 05:23 PM
*(330x32) for 04-10 "W219" CLS500.
*(360x36) for 11-17 "W218" CLS500/550.
-;ZAYED;-
Reply 0
Explore
Aug 20, 2018 | 10:49 PM
-;ZAYED;-
It is still tempting to go with the 360mm brakes and 8 pot calipers up front but that would add a lot of weight in the wrong places.
Reply 0
Aug 20, 2018 | 11:12 PM
That looks like it will fit
Reply 0
Aug 21, 2018 | 05:41 AM
Yeah, they will fit..
-;ZAYED;-
Reply 0
Subscribe
Currently Active Users (1)
