BAD NEWS!!! C32 3000$ diagnoses
Any other solutions for outsourcing parts for cheaper than dealership. They said if I am able to find parts and install with my mechanic then they will be able to program.
Otherwise one could just tow a nice new Mercedes, plug in another ME module, and enjoy the stolen car. This way someone has to have knowledge and equipment to program the replacement unit to the car.
This link will tell you everything you want to know:
http://benzbits.com/DAS.pdf
but I’m a little confused when it comes to the front SAM. When searching online I noticed some came with Wires/and Fuses and Some came without any.
So I don’t know which one to get, link below are the Front SAM’s
My Indie Mechanic also asked do I also need wire harness?
https://www.ebay.com/p/Mercedes-Benz-W203-Sam-Steuergerät-2035453701/1676930837
https://www.ebay.com/p/Mercedes-Benz...701/1676930837
Replacing the ECU is a matter of minutes. Replacing the SAM can be done in an hour if you know what you're doing.
Start with these folks. There are others out there.
http://www.mercedesecm.com/
Let us know how it goes.
Spoke with Dealer today, I asked if I could send my old ECM/ECU for repair/rebuild and he stated I’m going to need a new ECU because the old one has water damage. I then asked if I purchased a used ECM from eBay would the data be able to be transferred over and he said possibly but he won’t know until they get the new/used ECM.
SAM part number:
A 203 545 06 01 with note replaced by A 203 545 16 01. These are for code 494/581 (USA/Automatic Climate Control) which are listed on your car's data card.
if your in chicago i can have you see the car and you can take it for literally a steal.....
You MUST get an ME from a C32. The engine controls are completely different on a supercharged car. It uses speed/density instead of mass air flow to operate. It also has logic circuits to trigger the supercharger clutch and intercooler pump. A C320had no use for those things.
what is a ME? I need a ECM, not ME....
Im clueless as to what “DAS lockout” is...
Any part number I can search for that will give me the correct ECM for my vehicle
Here is the site of the place I will be ordering from once I get correct ID number.
https://automotix.net/usedautoparts/...UaAhaLEALw_wcB
Could this be the Front SAM and water caused carosion, somehow resulting in some bad connections or something To radiator fan...”just my guess”
or could it be the ECU?
What way would you guys go first, when going about resolving something like this?
