has anyone had to change rotors yet?
Old Jul 15, 2004 | 10:47 PM
vimzin's Avatar
06 E55 current, M5 Sold, C32 Sold, 330xi Sold
The dealer told me that I needed to change my rotors due to some vib when i was stoping. I have just reached 20,000 miles is this normal or no? also does anyone have an idea of how much this should cost as in labor and parts.
Old Jul 15, 2004 | 11:18 PM
Prasith32's Avatar
vimzin,
i had to change my rotors at around 20k but that was after a number of track events and running some street/track pads.
Depends on your driving style. Ask them to measure your rotors and ask for specifications on rotor thickness. They are required to give that to you. Also what may have happened is you could have scored your rotors. I did that by accident as i didn't know my brake pads were almost worn out during a long track session (55 mins) and I came back in and my car was making a horrible noise. It turns out my brake pad had almost split in half and scored my rotor.
So anything can happen. What is your driving style?
Prasith
Old Jul 15, 2004 | 11:20 PM
cschow's Avatar
2006 Corvette Coupe
Those symptons are commonly referred to as warped rotors, although the rotors themselves are almost never warped. Rather, whats most likely to have happened is that portions of your brake pad deposited onto the rotors causing the rotor surface to be somewhat uneven.
The solution is: new rotors, turning the rotors, or running race pads on the rotors for a limited time to "turn" the rotors using race pads. MB dealers never turn, they want to replace the rotors.
Luckily, the OE rotors for the C32 are quite affordable. I forget the exact price, but I had to get mine front rotors replaced earlier this year after a track event and the parts didn't cost much. I had an independent mechanic do the labor and I watched him change both the rotors and pads. The actual time to do both fronts was less than an hour, but I don't know what the customary shop time the dealer's service department will bill you for the procedure.
Old Jul 15, 2004 | 11:33 PM
Harris's Avatar
Or do you often wash your car while the brakes are hot???
Old Jul 15, 2004 | 11:45 PM
oggle's Avatar
E320
Does leaving rust on the rotors after a car wash lead to warped rotors?
Old Jul 16, 2004 | 09:33 AM
vimzin's Avatar
I guess this is a normal thing then i do drive my car hard at times.. also i do wash my car once a week usally, but i try and wait till the paint cools down..
should i replace my pads when I change the rotors?
Old Jul 16, 2004 | 11:03 AM
s4iscool's Avatar
no, that isnt really even rust, its the brake pad metallic matieral oxidixing with the water..it all gets brushed away after a couple stops.
Old Jul 16, 2004 | 11:58 AM
av2's Avatar
av2
C32 AMG
Avoid the parking brake after hot lapping or using your rotors intensively.
Old Jul 16, 2004 | 03:01 PM
oggle's Avatar
E320
So say I leave it on overnight after a wash. Nothing bad will come of it?
Old Jul 16, 2004 | 03:24 PM
Mach430's Avatar
The deposits you refer to are called pad transfer, which typically only occurs on a new pad/rotor combination. Pad transfer goes away over time (depending on braking habits/conditions). At 20,000 miles, the rotors are thinner than they were when brand new, and are likewise more susceptible to warping.
Old Jul 17, 2004 | 08:16 PM
RapidG's Avatar
C32AMG
At 22k, just had my third set of rotors installed yesterday (2nd replacement). I track my car quite a bit, so get alot of brake wear. OE rotors were shot by 7k. If you run your car on the track, when you pull off with hot brakes, avoid leaving your foot on the brake after you stop. It will bake some of the pad material on the rotors and will take 500 - 1000 mi. to wear off. When you stop, put your foot on the floor and leave it there!. Hard habit to break!. BTW, dealer cost for front rotors and pads - $630.
Old Jul 17, 2004 | 09:22 PM
s4iscool's Avatar
nah, you could leave it on for days...my vw i leave outside...it goes for more than a week at times with that oxidation on the rotors...no problem
Old Jul 18, 2004 | 02:27 AM
BlackC230Coupe's Avatar
Former Vendor of MBWorld
Fast Cars!
OMG! u can buy the whole kit with calipers, pads and rotors for less from evosport.
Old Jul 19, 2004 | 01:28 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
question: don't our pad have those wear sensors? I'm at 30k miles and haven't changed it.
Old Jul 19, 2004 | 01:42 AM
Fast Cars!
Originally Posted by FrankW
question: don't our pad have those wear sensors? .
There suppose to. :p
Old Jul 19, 2004 | 01:44 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
oh well, I'll have the thing checked when I do the service A again this week.
Old Jul 19, 2004 | 01:46 AM
Fast Cars!
Service A again? Whats after service A and B? i was never to clear on that?
Old Jul 19, 2004 | 01:48 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
it's just A and B over and over again.
Old Jul 19, 2004 | 01:52 AM
Fast Cars!
Oh? I never even knew that. I just had the serive B done on my CLK and was wondering why it said service A again in 10k miles. I thought it was a mistake. :p
Old Jul 19, 2004 | 02:09 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
btw, do u know if they cover schedule maintainance untill the original warranty expire??
Old Jul 19, 2004 | 02:24 AM
Fast Cars!
I dont know, i did not even know there were 2 service A's! LOL! I am guessing that its free till the warrenty expires tho. To bad my C55 does not have free maintainance!
