Quaife ATB Limited Slip Diff
#52
1 Post
M5, Model S, E350, M3, M635CSi...
1.) Drive a BMW with an LSD and see if its noisy. But be careful, don't drive an E46 M3 on the track or they'll be no turning back:-)
2.) Many clutch type diffs can use Mobil 1 or Red Line 75w90. Nothing exotic or to be feared.
4.) true
5). Ok, yes the diff can be plug and play but how well did it handle? You may get lucky but you never know. I've had several friends try Quaife's on BMWs and have to change there suspension set ups to make it work. I would be happy if someone is willing to do all the sorting.
3800-6300euro and you can't even get them here? That's ridiculous. I'd be raving mad to MB/AMG that they don't make an LSD available on this car. I hope they read these forums and get their act together. Or better yet you guys should start writing email/letters to them as owners. Get the owners on the other AMG boards to join you.
4.) true
#53
SLK32
4.) true
4.) true
2) Not sure about this one way or another. I do know people that spend ~$45 every diff fluid change at intervals of no more than 30k miles.
5) Car handled great. It was just an LSD so I went from 1 wheel spinning to 2 wheels. Outside of additional traction no change in handling. The car that did the install sets up many SCCA racers.
Hopefully there will be enough interest generated to get us an LSD at a reasonable price.
#54
MBWorld Founder
ones too fast according to CHP!
The e46 M3 is not a clutch type diff. In fact, that is one of the things we do to to upgrade it. It is viscous from the factory.
Brad
Brad
#56
Originally Posted by Zeppelin
One thing to remember is that ASR which is the traction control of the ESP system only operates below 40kph. So this artificial LSD called ASR does no good above 40kph (about 25mph).
http://www.virgeweb.com/rage2/misc/SLKASRDemo.wmv
ESP light blinks throughout the slide even though it's off (I'm assuming that's ASR LSD simulator triggering). And the rear rotor on the inside wheel overheats and discolors. ASR does try to get the wheelspeeds back together (LSD simulation), but obviously from the tiresmoke on the inside wheel, the ASR system is overwhelmed and it's not working. There's still some wheelspin on the outside wheel thanks to ASR, which allows the slide to be held for that long.
I spoke with Kleemann regarding their LSD package offered on their web site, it's only available to V8's. Sorry, no C32 or SLK32's. They did also tell me that there's no ESP reprogramming required. The ASR portion of the code will never get triggered with the LSD in place. Also, the ESP system is designed to work with both ASR working properly (ie wheelspeeds close) as well as when one tire is off way faster than the other as shown in my video.
BTW - I'm up for the LSD if its in the $1500usd range.
#57
Very nice car control. I like the last jog through the last cone that requires you to change direction.
Most advertised Quaife's in the mags this month are typically $895.00.
My rear brakes are fine and not overheating during extended drifts, nor were my fronts when running CW with equal tire circumference.
#59
Originally Posted by Lucas
The C32 / SLK32 use a large case V8 rear axle ( same as W210 E55 ), so KLEEMANN have the LSD in the program for these cars.
#60
Originally Posted by rage2
I'll call again tomorrow. The guy I spoke with said it's not available for C or SLK class, regardless if it's the 32.
now that's kind of a funny way to respond.
#61
That's not true. If that was the case, this would not be possible:
ESP light blinks throughout the slide even though it's off (I'm assuming that's ASR LSD simulator triggering). And the rear rotor on the inside wheel overheats and discolors. ASR does try to get the wheelspeeds back together (LSD simulation), .
#62
Can someone post the technical descriptives on this alphabet soup.
Regarding the video, this illistrates how the open differential behaves during a power slide/drift through a radius corner. The inside or passenger side rear tire in this example is spinning more as it has the least traction. If a LSD from any manufacturer was installed, would you be able to execute this same manuver? Less wheel spin, less attitude? Same wheel spin, only both sides spinning at the same rate? Easier to control during manuver or more difficult? The LSD may lower my points and smoke factor at the next drift competition!
#63
Well if it is not true then MB is lying in there own Technical Papers on the operation of ASR. Besides if you turn ESP off through the switch you are turning off ASR, not ESP. The fact that the triangle is flashing is just telling you that ESP is being triggered. I am unable to view the video due too some codec issue.
Here's my experience with ESP behavior. All based on track experience experimenting with ESP. I'm sure the evosport guys can comment on this too, as they've done a lot of track time with their C32.
With ESP on, the first 2 laps around the track, you'll be slow. It'll start braking at 9/10ths entry speeds into all the corners. It basically won't allow ANY additional slip angle as compared to where you're steering. Because of this, it'll slow down entry speed significantly to bring you down to about 5 or 6/10ths cornering speeds. At exit, it'll also restrict power because it doesn't want any rear slip angles, so exit speeds are horrible.
After about 2 laps on the track, it realizes that you're on the track and want to go hard, so it starts to allow SOME slip angles. You won't be able to get extreme angles like in the video I posted, but you'll be able to get some, enough to drive really fast. In some cases, if you enter the corner too fast, it'll be able to correct it by lightly braking an individual wheel, so you don't spin out, but still sustain the entire mid section of the corner at the limits. very Fast in-fast out, a little faster than with no traction control thanks to the quicker turn in. I have telemetry from GPS data logger to prove this behavior. It's hard to replicate because if you do go past a certain threashold, ESP kicks in HARD and you lose a lot of speed.
OK, now with ESP off. Magazines and people have complained that with ESP off the system is still sort of engaged, some sort of a backup system. In most track driving situations, if you're aiming for speed, ESP will not trigger at all. It'll only blink at exit, when you lay down too much power, which is the ASR LSD simulator trying to get the wheelspeeds back in sync.
So when does this backup system trigger? I've had it trigger in 3 situations.
1. When I apply moderate brakes mid corner to adjust the attitude of the car during a drift, it'll kick in and slow things down ruining everything. Very light taps on the brakes will work fine, moderate to hard will have the system ABS'ing a bunch of individual wheels to try to stop you.
2. When you turn into a corner hard to get the rear to swing out, it thinks it's in an emergency lane change situation, and doesn't allow rear end to slide out. If you watch my video, you'll notice I'm gentle turning in to get the rear to progressively slide out. This is done to not trigger "backup ESP" in this situation.
3. When you try to transistion from a left drift to a right drift, if the transition is too hard, it'll kick in because it thinks you're in a "tank slapper" situation and basically slow the car down huge. Same theory as #2, thinks it's an emergency lane change situation.
So there you have it, my run down of ESP and how to work around it. I haven't read any white papers at all, this is all from a lot of experimenting on the track to understand the system more.
In this video example, if you listen to the engine note carefully, I'm varying throttle from ZERO to WOT constantly. Gives a lot of smoke (and wear) on the inside tires, but it's the only way to get some slip on the outside tire from ASR putting a bit of pressure on that inside wheel. With a real LSD, a lot less throttle for the same drift angle/line, and a lot less tire wear.
![](http://www.virgeweb.com/Ben/psylence/DriftFun-071204/008.jpg)
#64
1 Post
As Rage2 said you definitely want an LSD for drifting. If you are using clutch type LSDs you want a pretty high lock-up % like 60-80%. The drifting topic brings up an interesting idea. Perahps an LSD company that cators to drifters would be more flixible and willing to work on a C32 LSD. Kaaz perhaps http://www.kaazusa.com/
#65
MBWorld Founder
I think that the Kleemann might be a great way to go. This is news to me that Kleemann actualyl has a diff that will work, but if they do, it is worht a serious look. Brandon (Kleemann US) has a great knowledge about MBZ differentials and has the computer capabilities to make some things work that others cannot.
Brandon?
Brad
Brandon?
Brad
#66
Location: Great White North (the one with the crappy dollar)
2002 c32
How about..
Brandon?
Brad
Brandon?
Brad
a LESS instrusive ESP for starters. I would probably spend $ on this mod b4 the Pulley Upgrade (which is also on my scope for next year)!
TIA
lap
#67
some good posts on the LSD option by AMG here
http://www.amg-owners-club.org/board...?threadid=1787
Here is the thread with a bunch of links on the topic
http://www.amg-owners-club.org/board...?threadid=5301
#68
TIA
lap
TIA
lap
Lap,
If the LSD is doing its job I suspect that the ESP would be less intrusive by the general nature of the programming. However you never know as even little tire imbalances seem to affect it at certain places.
Prasith
#69
Spoke with Kleemann again, different guy.
The LSD *is* available for C32 and SLK32, so Lucas was right! (thanks). $2300 for the kit, you take the diff out, open it up, and instructions on installation of everything is provided with the kit. Gear oil is included as well. The installation of the kit takes about 2 hours. The tough part is the removal and reinstallation of the differential itself. No ESP adjustments, they've had zero problems during testing.
There is no quantity purchase price. $2300 is the price, that's it.
#70
Any more info on the Kleeman LSD:
Is it a Clutch type?
Is it a Viscous type?
What percent locking is it
Can it really be installed in 2 hours by a shadetree mechanic? Or does the backlash/endplay/gearmesh pattern all have to be adjusted(therefore big buck install)
#71
damn... far off than smgc32 suggested price on the Quaiffe...
i wish Quaiffe will make some in the future... and Cheaper!
i went track lap today... i driven so hard that pulling 2 stis and 1 stock supra away or catching them up from behind... but man, our car needs LSD![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
i can't believe the only one close to me was a E36 328is with cam, manifold, LSD, finalgear and suspension mods. That car is soooo fast in the corner...
#72
Brandon?
Brad
Brandon?
Brad
Meanwhile contact EvoSport for your C32AMG LSD needs. $2300 for the package, requires skilled installation.
#73
2006 Corvette Coupe
Can Evosport and/or Kleemann confirm that the Kleemann differential is capable of withstanding the power/torque of a C32 modified with Evo's performance upgrades? My stage-1, Y-pipe, and plug/wires should be on their way to me from Evo soon ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
A bit off topic here, but anyone who got Evo stage 1 with the raised Vmax limiter is lucky! I inquired about this with my stage-1 but apparently its now only part of the stage-2 software.
#75
Originally Posted by cschow
Can Evosport and/or Kleemann confirm that the Kleemann differential is capable of withstanding the power/torque of a C32 modified with Evo's performance upgrades? My stage-1, Y-pipe, and plug/wires should be on their way to me from Evo .
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
