harsh ride at 24k miles, is it normal? rattling, squeaking.
I have a stock '02 C32 which rides so harsh ride now that I no longer feel comfortable driving the car. Is it normal for the suspension to wear out at this point of the car's life? Will I be able to get the dealer to replace it for me under warranty?
And one more thing is that the front suspension (at least thats where I think its coming from) is squeaking and rattling on uneven roads. I know that the squeaking is widely known but for the rattling, do you guys know what may have caused it? Thanks
have you checked tire pressures? They go up during the summer and those can affect ride greatly. The difference that 5 psi can make is remarkable.
Other than that it could be bushings but they don't usually make the ride harsh. Have you checked to see if you wheels are properly balanced? Sometimes having the balance off can cause vibration and cause a false sense of harshness.
Im going to get hit with a stick here but here we go anyhow!
I am ultra picky and maybe you are as well. MB shocks do not "wear out" at 30k miles but around 40-50k they get soft to the point where I would change them. The factory would call them with in spec but I dont like the car feeling "old" so I would get new ones at this point.
If you have a harsh ride, the bushings can be at fault. If a bushings fails or becomes very firm it could cause a vibration and also make the car ride very poorly. Normally this happens around 100k miles but I have seen it happen as early as 20-30k miles.
Have the dealer ship look at it and see what they think.
Good luck!
just ask them to check for the squeaking sound coming from the front suspension. they found mine to have some problem w/ the thrust arm, so they ordered the parts and i'm still waiting.
FYI, I suggested the sway bar links but he said MB links tend to click rather than squeak.
They replace both (!) thrust arms!
I had also complained that the braking did not seem as good as my previous E36M3. I would apply the brakes and the car did not seem to slow as "fast" as it should I and would end up applying a lot more pressure near the end causing passengers to fall forward. I think this was also a symptom of the bad thrust arms.
