Rear Brakes
Old Jul 29, 2004 | 04:34 PM
MiamiAMG's Avatar
C63
Rear Brakes
Does anyone know if the E55 rear brakes fit the C55?
They are AMG 13.0'' perforated and ventilated rear discs, 4-piston fixed-type rear calipers.
I know that RennTech sells a rear Brembo brake kit, but i'm curious if we can fit the E55 ones on.
tia
Old Jul 29, 2004 | 04:40 PM
Harris's Avatar
Do-able but with modifications. The E55 brakes are pretty heavy. Mind as well get the Brembo 8-piston front and 4-piston rear.
Old Jul 30, 2004 | 02:24 AM
VancouverC32's Avatar
C32
Harris:
I have been meaning to come by to get some mods done, but my life is extremely busy. Could I just get the rear Brembo's as I do not like the look of the stock or would this not function well? How much for just back or both?
Old Jul 30, 2004 | 02:30 AM
Harris's Avatar
Originally Posted by VancouverC32
Harris:
IMO, just changing the rear brakes to Brembo doesnt really serve any purpose other than it will look better. The front brakes are used more often than the rears. I would rather spend money on changing the fronts. The stock rear brakes on the C32 arent that bad, they are the same brakes found on the W210 E55.
No worry, give me a call whenever you're available. I am always in and out of my office, better call me before you pop by.
Old Jul 30, 2004 | 09:15 AM
BenzoAMGpower's Avatar
Cars and boats!
i say get the 14" 6 piston upgrade for the front and relocate your front brakes to the rear!!!
Old Jul 30, 2004 | 10:52 AM
MiamiAMG's Avatar
C63
I never thought of that, can you do that, do they fit?
Old Jul 30, 2004 | 11:07 AM
smgC32's Avatar
The C32 utilizes the same rear hub as the E Class. You can do anything if you are willing to pay for the design.
Never upgrade the rear before the front as you will get too much rear brake bias. The rear upgrade in a BBK will offer a small improvement in braking capabilities. What is important in brake upgrades is their ability to shed heat effectively and reduce unsprung weight. Upgrading to a larger stock rear brake caliper and single piece disk will do nothing but add weight to the rear axle. Upgrading to better pads with a higher friction coefficient will produce better results on the stock rear brake system.
Brembo does not offer a six piston caliper for street application as far as I know unless you select from their racing parts bin and these units including their eight piston designs are not appropriate for street use and require frequent rebuilding. Maybe you were referring to the 6 piston AP's?
Old Jul 31, 2004 | 01:04 PM
CynCarvin32's Avatar
Mercedes Benz
SMG,
The 2005 CLK55 and SLK55 both use a 6 pistron Brembo caliper for the front and a 4 piston rear caliper. Not a racing part but instead a OEM part. It does look nice and uses a composite rotor as well. AMG is learning to put more brake on their cars which is a very good thing.
