Engine Swap mechanic wanted! USA
Old Oct 16, 2020 | 01:24 AM
CedricS's Avatar
Mercedes CLC 350 CL203, C63 W204, C350 Brabus 4.0
Question Engine Swap mechanic wanted! USA
Hey everyone!
I'm looking for someone that successfully swapped an engine in a W203 / 209 chassis. Including programming ECU, other modules and ESP/traction control obv.
Starting mid next month, i want to swap in a different engine and transmission. Its either gonna be the 5.5 V8 Kompressor or more likely the 6.2 M156. I know that Georgi Benz had performed an engine swap to his C55 but cant find any info or contact really.
No need to tell me that engine swapping is not really possible because there is not enough space in the engine bay, not cost effective or similar. Space is no problem on a CLC (CL203 chassis) and cost for the project is not really a big concern tbh.
If you have done similar or know someone that has the equipment and knowledge please contact me via forum PM or alternatively send me an email (cedric.2010@icloud.com).
As mentioned, the project should begin mid November preferably. The car is currently in Newark waiting for it to begin. I'd have it transported to the required location.
Not necessary but appreciated:
- look for engine and transmission in the area by yourself, maybe you have some connections if you are in the business.
- performing the swap in a quick manner
- documenting the process a little with pictures
If you have any contacts, let me know.
Old Oct 16, 2020 | 09:45 AM
eurochargedw210's Avatar
w210 E55
Originally Posted by CedricS
Hey everyone!
JUNEBLOOD on instagram has swapped a 156 into a 203
Old Oct 16, 2020 | 05:44 PM
ODB's Avatar
ODB
2006 C55, 2024 GLC300 SUV
wait, you have clc in USA?
Old Oct 16, 2020 | 08:19 PM
CedricS's Avatar
Yes and no. Its a temp import but when i brought it over i got registration documents. Its a full spec CLC 350
Old Oct 17, 2020 | 01:46 PM
ODB's Avatar
ODB
this may be interesting to you then. it is in russian though and about clc, but they are almost the same with clc
https://www.benzclub.ru/forum/showthread.php?t=289249
Old Oct 17, 2020 | 03:13 PM
CedricS's Avatar
Yea C Sportscoupe and CLC are well identical .. exterior facelift pretty much. I've seen pictures of the project forum but could never find anything else. Except for the final video:
Wouldn't go as crazy though. The way it might have come from a factory. Tbh im thinking about getting a CLK63 and then have someone swap the engine, transmission, brakes, rear diff etc. That way i have all the pieces of the puzzle.
Old Oct 19, 2020 | 12:32 AM
Michael McNair's Avatar
C32 AMG
That vid and build thread are absolutely awesome! I’ve owned 7 VW Corrado’s in varying states of tune from 158hp to 556hp and always wished someone would make a modern Corrado. This is the closest thing to it I’ve seen! I’m a die hard Benz guy too, so you have forever changed the goals I have.
must
build
one of these!
back on topic: I’m in PA and also interested in what your doing, and Newark isn’t that far from me. I’m following this closely and if/when I can help out I will be glad to. 👍🏻
Old Oct 19, 2020 | 12:45 PM
CedricS's Avatar
must
build
one of these!
Imo projects like this are so special. I love seeing what people can come up with. You are almost always more than surprised.
If there is something you can help with, ill let you know asap
Old Jan 2, 2024 | 03:33 AM
josh-benz1's Avatar
c63s coupe w205
C63s coupe front end schematic
Hi guys I’m new here, I’m looking for a front end schematic.. managed to stick my coupe into a field on the last day of the year😅. A lot of broken plastic and 2 broken radiators and and oil leak. So just need to look at what parts need to be replaced etc.
and help would be appreciated!
