Start up shut down
Please i need to now is there another alternative i do not think there is full honesty on this mechanic behalf .Thanks for listening.
Maybe a fuel pump.
Did you (or the previous owner) recently replace the fuel filter? From what I understand, the OEM fuel filter incorporates the pressure regulator, which the aftermarket filters are missing. Maybe it is just clogged or water or debris in the fuel tank.
Could also be the ignition system.
I'd get another mechanic to look at it. Just like a doctor, a second opinion can't hurt - especially when you're talking about an engine (after already replacing the transmission, etc.) I'd certainly be questioning this guy's competence/motivation $$. (Did the transmission really need to be rebuilt, or just a new conductor plate?)
Thanks for the advice
Did you use an OEM fuel filter?
WHen it starts and I put it in gear drive or reverse it will shut down but it will start right back up .I tried charging the battery and it will start and drive when I put it in gear but only for maybe a block than shut off ,so I bought a new battery and that wasn't the cause either still need help
Have someone else diagnose it and if I'm right, make the guy stand behind the work he already did and fix the darn transmission correctly.
What indicated that it needed a new transmission in the first place? Seems like a strange assortment of things to replace (but not completely unheard of). What were the initial problems before any work was done?
Also, check the battery. A weak one will cause really weird and random problems.
Report him to the cops for fraud.
Take your car on a trailer if it can't drive anymore?
Then expose this dishonest schmuck on all car forums to warn people not to bring their cars to this shop.
What's the name of the shop?
What city?
What city?
America is the land of lawsuits.
I doubt this guy will do anything right he could have messed up everything on your car and it probably won't be fixed the way it should?
Shady and dishonest mechanics are everywhere even dealerships have employees who shouldn't work on customers cars.
Name & shame is the only way to go with appalling shops and cheating mechanics!
Only way is to blacklist.
