1/4 mile times
Old Sep 6, 2004 | 08:49 PM
vimzin's Avatar
06 E55 current, M5 Sold, C32 Sold, 330xi Sold
1/4 mile times
Ran my car this weekend launched it at 1400 rpms and got a 13.8 and my trap speed was exactly 102.68 both times that I ran the car.. I expected to get a little better time any tips on getting a better time? is this an avg. for everyone or is it a little on the slow side?
Old Sep 6, 2004 | 08:59 PM
jcanabal's Avatar
2006 SLK 55 AMG
My best is 13.7! Norm's C32 (RIP) was doing better than mine but there are two others at Starfest that could not do any better! It was a very hot day! So....I guess it's normal times for non-experienced drivers like us!
Tips.....I'm not a good source! Still a rookie!
JMC
Old Sep 7, 2004 | 02:04 PM
BenzoAMGpower's Avatar
Cars and boats!
its a bit on the slow side... i would expect at least a 104mph trap speed especially with a 13.8 1/4 mile time, it sounded like you were spinning a lot!! but then again what elevation was it where you ran it?
Old Sep 7, 2004 | 06:15 PM
dsC32's Avatar
'07 E63; 05 C55 gone; '02 C32 gone;1996 SL320;1978 280CE Gone
At StarFest I had three 14.0 times at 103+ mph.
Old Sep 7, 2004 | 06:16 PM
ntguru's Avatar
C32 AMG
1/4 times
My best run was 13.4x @106 on Pilot Sport A/S tires. I consistently ran 13.8's just by stomping the gas pedal. Your trap speed is very low, especially considering your pretty high E/T. I'm guessing your car wasn't or isn't making full power. What were the weather conditions and are you at any altitutude? If it was not hot and you're not in, say, Denver, I think something is up.
Also, what happened to Norm's C32?
Old Sep 7, 2004 | 08:43 PM
Vomit's Avatar
2002 C32 Black/Charcoal
If you are stock on Pirellis, a 104 trap speed, give or take 1-2 MPH, is normal (the Rosso/Neros seem to get really crappy launch traction). The Toyo T-1s is a much better launch tire, as is the PS2, the Bridgestone, and the new Goodyear. If you are on Pirellis, expect to waste a lot of time spinning at the start.
Also, what octane were you running? You will lose a lot of power at high RPMs with 91 octane (I notice that my car pulls hard right to the shift point on 93+ octane, but seems to sort of die of asthma at 5800 RPM with 91 octane). Try better fuel next time. Add some Toluene.
Also, there is the weight issue. Remove your spare and any other removable weight. Run with 1/4 to 1/2 tank of gas (saves up to 100 lbs versus a full tank).
Finally, what was the temp out? By my calcs, the C32 loses roughly 0.1 second in the quarter for every 10 degrees farenheit increase in ambient temperature.
Lastly, don't get discouraged. Your car will vary a lot from day-to-day, and your times will definitely improve with experience!
Old Sep 8, 2004 | 10:10 AM
E55 RUSS's Avatar
E55K
Hey Miami Benzo what are you running in 1/4...with a ECU and pullies...
Old Sep 8, 2004 | 11:07 AM
vimzin's Avatar
I am running on toyos already which is why I was upset I think I did lose some grip with my launches at 1,400 rpms.. I dont think the temp was a problem since it was around 70deg that night, but maybe the humidity. not sure the elevation I am located in richmond Va and I am using 93 chevron. once all this rain clears up I think im going to give it another shot and let you guys know how I do then.
Old Sep 8, 2004 | 11:08 AM
Carl AMG's Avatar
2002 C32 AMG Orion Blue Charcoal/Blue
I had similar times at Starfest with a best being 13.9 (the first run...got slower as the car got hotter). However, these times aren't representative of typical times because it was hot outside and the track wasn't giving good traction. Most of use were running R compound tires (mine being oversized front and rear) and weren't warming the tires with burnouts. The best 60 ft. time I could get was around 2.25.
The only other time I hit the drag strip (MIR in Southern Maryland) it was much cooler. My best was 13.4 at 105 with a 2.0 60 ft time on the OE Michelin Pilots.
Old Sep 8, 2004 | 01:41 PM
Vomit's Avatar
Hey Vimzin:
I have run at Carlsbad Raceway (now closed. . . R.I.P.) with a few other C32 owners (some stock, some modded), and your stock time is a better than average, with your stock trap speed a little worse than average. It sounds to me like you are probably getting a solid launch, but either weight or HP is letting you down. Are you carrying a spare? Full gas?
Especially if you already have some significant mileage on your car, I would try a couple of simple, inexpensive mods (all of which I have done, and can vouch for): Optima battery, K&N filters, Denso Iridium plugs, Magnecor wires. This group of mods will cost you roughly $500.00, and I would be very surprised if you didn't see a noticeable improvement in your 1/4 times/speeds.
Also, keep an eye on barometric pressure. Supercharged engines suffer when pressure drops (I think that I am correct on this one, but feel free to roast me if I am not!)
Old Sep 8, 2004 | 02:07 PM
Cars and boats!
my cousins got the same exact car with the RENNTech ECU and Pulley kit alone at Moroso in about 68 degree weather... he was pulling 12.8 @ 110mph on nearly bald pirellis at the track about almost year ago but we havnt been back to the track since..on the same night i was pulling 14.7 @ 95mph in my ML55 (renntech CF airbox and ECU upgrade but with heavy heavy 20" carlsson wheels and full sound system in back)!!!
I havnt had a chance to take my C32 to the track with all the rain taht has been comming through here lately, I have ECU, Pulley kit, and SL55 intake splitter as far as engine mods go!!!
Old Sep 8, 2004 | 02:47 PM
Zeppelin's Avatar
C32
Originally Posted by Vomit
Hey Vimzin:
Vomit - I figured it would take a 1/4 mile thread to bring you back to the forum. What do you mean Carlsbad is closed? Is this for good?
Tim
Old Sep 8, 2004 | 03:49 PM
Vomit's Avatar
Hey Tim!
Good to hear from you. Hope all is well.
Been busy brokering pain. But, you know me, can't resist drag. :v Actually, seems like all the C32 freaks are neutered now that the big, bad C55 has come along. I still haven't seen one on the road. I can't wait to fart some C32 supercharger exhaust on the windshield of some unsuspecting, overpaying C55 owner.
S.D. Union Trib a few weeks ago. . . article said that Carlsbad Raceway was latest victim of encroaching housing development, and was closing for good. So now, where do San Diegans go for racing? Any ideas? Isn't there a strip up there? Let's get a drag race day organized.
Old Sep 8, 2004 | 09:05 PM
vimzin's Avatar
Hey Vimzin:
where can I get the battery, plugs, wires from? How can I keeep an eye on the barometric pressure and what is it suppose to be at? also I dont have a spare and my gas was pretty full when I ran.. .thanks for the tips Vomit
Old Sep 8, 2004 | 11:07 PM
Vomit's Avatar
Vimzin:
This would require a complete rehash of many threads discussing these mods. Click on "Search" on the blue bar above, and search the C32 forum for each of these terms: 'Optima' and 'Magnecor' and 'Iridium' and 'K&N'. Each of these mods is described in one post or another, along with phone numbers or websites where the items can be purchased. After you decide what you want to purchase, you can search these terms with your regular internet search engine, and you will find retailers.
If you really get stuck on one or more of the products, let me know and I will get off my lazy **** and do the research (again) as to part #'s and retailers.
As for barometric pressure, you can buy a barometer at Wal Mart, Sears, Frys, etc.
Good luck.
Old Sep 9, 2004 | 01:15 AM
TC32AMG's Avatar
C32AMG
Pretty close to what I ran the first time out with my C32, practice will also help get those times down. After about 20 runs I was pretty consistently running 13.5's with a best of 13.2
I think Vomit's suggestions on mods are good and should help and are fairly inexpensive, also I saw Pierre32///AMG do a mod on his airbox with thermotec tape, that should help as well as that airbox gets heated up by the engine and exhaust.
With my mods (chip and Pulley) the car is running pretty consistent 13.3 with traction being the problem haven't, broken into the 12's yet
But I did some rough calculations on gear ratios and found that the C32 shifts from 3-4 very near the end of the 1/4 mile at about 106 mph. Which I did notice on my last few runs. Next time out to the track I am going to see if short shifting 3rd at about 95 will help my trap speed a little or ET
I heard that the Renntech slk32 with the 3.8 conversion not break into the twelves, but a higher/lower ratio (~2.80:1) would make a difference in its 1/4 mile times.
Old Sep 9, 2004 | 07:52 AM
E55 RUSS's Avatar
E55K
CooL... 12.8 is Fast...
A freind of mine runned a 13.03 in his M5 with no Cats...and bold tyres...I did do any runs as well...We have no drag strips....
Some people on M5board seem to be able to 12.73-12.80's...with stock M5...
What they did is 1st to let the car to cool down for 2 hour the make a run....
Old Sep 9, 2004 | 09:35 AM
vimzin's Avatar
Theres a guy on my forums that I admin with a stock m5 running mid 12s his plate says 12snm5 but, hes very into going to the track every week almost.
Old Sep 9, 2004 | 09:39 AM
E55 RUSS's Avatar
E55K
These could be possible if his M5 runs slicks...
Old Sep 10, 2004 | 04:42 PM
dsC32's Avatar
I was also running Pilot Cups, 255/40-17s in the rear, but SO3s on the front. I guess I'll have to consider that my car is always a few tenths slower in the quarter mile than most C32s. I'll compensate with consistent 26-27 mpg on the highway that most of you guys don't get.
