C55 Vent Dial Lighting
Old Jun 19, 2021 | 06:43 PM
brauhaus313's Avatar
asdas
Do your C55 vent dials light up as in the attached pic?
None of the dials light up in my 2005. Was this something that was deleted for the US?
Old Jun 19, 2021 | 08:40 PM
FortySix&Two's Avatar
None
Interesting…Could that just be the lighting? Just checked mine & they don’t light up either.
Old Jun 20, 2021 | 01:47 AM
asdas
I'm pretty sure in the pic the dials are backlit. I have read that some models in later years of the W203 had backlit dials. Should mine be lit is the question.
Old Jun 20, 2021 | 12:16 PM
ODB's Avatar
ODB
2006 C55, 2024 GLC300 SUV
it comes together with that "digital" climate control unit. I think it was never available in US for C55.
Old Jun 20, 2021 | 07:30 PM
asdas
Huh...interesting, and a shame. Would add a nice touch at night.
Old Jun 20, 2021 | 11:51 PM
PJmak's Avatar
Hmm ill check mine but I doubt it. What about steering wheel buttons? I dknt remember those being lit?
Old Jun 21, 2021 | 04:31 AM
asdas
My steering wheel buttons light up.
Old Jun 22, 2021 | 11:46 PM
BF_JC230's Avatar
2005 w203 C230
I just finished mine…
I’m currently working to convert the PWM signal to the blower fan back to a stable DC signal to trigger a relay to illuminate the actual vents…
https://mbworld.org/forums/c-class-w...ob-lights.html
If you go down this road, the back vents particularly, I found laying fabric looming tape inside where plastic rubs plastic to have greatly reduced the creeks and squeaks…
Old Jun 22, 2021 | 11:49 PM
BF_JC230's Avatar
2005 w203 C230
Now I just need to install the ambient door lighting…
https://mbworld.org/forums/c-class-w...oot-legit.html
Old Jun 23, 2021 | 02:54 AM
asdas
Interesting. Why do you have to take the signal from the blower? Is that how the lights are wired from the factory if equipped? Still find it super annoying that this was left out on our C55's.
Old Jun 23, 2021 | 05:04 PM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
I believe the vent wheel lights are wired to a switched source that comes on with the external lights. This has been the case with all the models I've owned, W124, 210, 164, 166.
Old Jun 23, 2021 | 07:31 PM
BF_JC230's Avatar
2005 w203 C230
Thanks for the question!
The OEM knob wheel lights get power from light switch/internal lighting circuit which is gray with blue stripe wire. I have them, as well as the shifter on this, the ashtray/cubby light circuit.
The vents will illuminate when the HVAC system is on AND the lights are on using the same circuit for power, but switching over from a signal lead activated by the PWM motor. All lines before motor regulator are monitored…
The door panel ambient light strips will get power from the illumination signal wire to the switches…
Old Jun 24, 2021 | 03:12 AM
asdas
It is my understanding that this is how they would/should be wired as well, or rather come on when at least the internal night time illumination is on. I think it's pretty much the same in any car.
So your dial lights will illuminate as normal and as Mercedes wired them, but you've added your own vent "background" lighting that will only turn on when the night time lights are on and the HVAC is running, right? Curious.
Old Jun 24, 2021 | 09:53 PM
BF_JC230's Avatar
2005 w203 C230
Yes. That is all correct.
Old Jul 14, 2021 | 12:50 PM
BF_JC230's Avatar
2005 w203 C230
Here is a link to the DIY ambient interior door panel trim light project for the w203…
https://mbworld.org/forums/c-class-w...ht-strips.html
