C55 TUNING w/ Powerchip - DYNOs
Old Sep 23, 2004 | 05:51 PM
Vadim @ evosport's Avatar
C32 AMG
BLUE Run is stock C55.
RED Run is after tuning with POWERCHIP software. 12-14HP and 13-18 ft.lbs. of TQ.
GREEN run was with PC software and Air Box completely removed. We just installed a short 5'' hose to straighten air flow into mass-air sensor. There is another 7-9HP in better air box design.
So what else can be done to C55? Underdrive pulleys should add 5-7HP, we are going to try to see if our E55 headers will fit or can be modified to fit. They should be worth another 15-20HP. After that a set of mild cams can add another 15HP. That should be enough to get above 350 WHP. Beyong that going normally aspirated will require head porting and intake manifold mods, those should push power to 370-375 RWHP.
On forced induction front there is Kleemann, and the SC should push rear horses to 430 RWHP without above mods and to over 480 RWHP with them on.
Now, how does C55 compares to C32?
BLUE run is strongest stock C32 we have dynoed. Most average out to around mid280s, some are as weak as 265 RWHP.
RED run stock C55.
Since C55 is about 70-100 lbs heavier than C32 and has an extra 10 lbs. of TQ in midrange, I would say both cars should be very, very close at drags.
Old Sep 23, 2004 | 07:05 PM
JAYCL600's Avatar
new balance
Vadim,
Nice numbers...not to get off topic, but I wonder if my w210 would have similar results from just chip tuning?
Jason
Old Sep 23, 2004 | 07:47 PM
SiLvaC32's Avatar
C32
very nice numbers!
Old Sep 23, 2004 | 11:45 PM
C32 AMG
Yes - C55 has slightly higher compression, other than that both motors are the same.
Old Sep 24, 2004 | 12:05 AM
JAYCL600's Avatar
new balance
What is you charge for chip tuning and can you email any dynos you may have for a W210 with chip tuning to amgpwr2000@yahoo.com thanks in advance.
jason
Old Sep 24, 2004 | 01:18 AM
rbaker's Avatar
Z06, M3, Mini Cooper S. Sold: C55
Looks good Vadim... I stopped in to see you guys the other week but the only one there was a tech working on his car. Need another C55 guinea pig?
Old Sep 24, 2004 | 03:18 AM
Psychoburn's Avatar
2005 White C55
that's a lot of hp loss isn't it?
Old Sep 24, 2004 | 12:24 PM
C32 AMG
E55Jay and rbaker, I will have Simon get back to you with more info.
Psychoburn: I like to use 17% loss, so 296 / 0.83 = 356HP. AMG rates the car at 362HP, so we are pretty close. In addition C55 was under 2000 miles, so my guess is - the motor will loosen up with mileage.
Old Sep 25, 2004 | 09:22 PM
Psychoburn's Avatar
2005 White C55
Hey vadim, i'd like some info about the chip and tuning for my car too =) Could e-mail to jtyen@uclink.berkeley.edu thanks!
Old Sep 26, 2004 | 12:42 PM
Norm C32's Avatar
ex-C32
The C55 that was brand new at MBCA StarFest(Mid-Ohio) ran a 13.8 @ 103 MPH to my C32(Father driving) 13.7 @ 104. With more break-in time the C55 would be even closer. The torque of the C55 really proved itself on the autocross where it smoked all the C32s.
Norm
Bordeau/Merlot
Old Sep 27, 2004 | 12:58 PM
elboricua's Avatar
2000 E55
e55jay can u pass down the info on the w210 to me plz.
