C55: Can't find coolant leak!
BTW, perhaps it's implied when you said "no coolant in the engine" but are you getting any white smoke from your exhaust? Possibly headgasket.
The leak at the y pipe is a common issue on these cars.
I have one of these and it works quite well.
Wiper arm puller.
When it comes to the cowl, start at the corners. I will share the video that helped me when I find it. It was a pita to figure out on my own because it seemed impossible.
Worse comes to worst, I think a new wiper assembly is less than $100.
https://www.mboemparts.com/oem-parts...UtNWwtdjgtZ2Fz
Luckily it is the highest point of the coolant system so just shutting the car off should prevent further leakage and damage but still not something Id want to deal with.
When removing the cowl, you are gonna want to start from the corners. Its snapped in and is in there good. Get under it using some sort of plastic pry bar and lift the corner and youll have to pull on it good
