moldy smell after washing car
Old Nov 3, 2004 | 05:59 PM
psk145's Avatar
2006 E55
does anyone else get a moldy smell on the inside after washing their car? Mine does everytime but it goes away after a day or so
Old Nov 3, 2004 | 06:27 PM
Marktini's Avatar
2006 SLK55 AMG/// 2006 Porsche CaymanS 2010 135i
Only If I leave my wet towels in the trunk...
Old Nov 3, 2004 | 07:37 PM
Vader13's Avatar
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
Weird..
Old Nov 3, 2004 | 09:28 PM
Taucher's Avatar
2002 C32 AMG
No, but I wash mine with the windows UP ! ! :p
Old Nov 4, 2004 | 08:51 AM
viper's Avatar
You probably have a leak in your weatherstripping somewhere. Check the trunk and around the doors and find where water is penetrating.
Old Nov 4, 2004 | 09:23 AM
©32's Avatar
C55 AMG
Check the A/C filter... water might have leaked into it
Old Nov 4, 2004 | 11:38 AM
MK899's Avatar
2002 C 32
Sometimes I get a moldy smell from the A/C. When the A/C is turned off for around 10 min. and then restarted, the smell will appear.
Old Nov 4, 2004 | 11:42 AM
moa4r's Avatar
S4
try this stuff called figifresh, its supposed to work for that wierd muggy smell from the AC vents
Old Nov 4, 2004 | 12:52 PM
psk145's Avatar
2006 E55
no water is getting past the seals on the door so I dont think thats it.
It doesnt stink when I turn my AC on, so I dont know if thats it either. Maybe something crawled into my car and died
Old Nov 8, 2004 | 06:10 PM
KompressorKev's Avatar
'14 428i M-Sport, '02 C32 AMG
i noticed that when accessing the battery, there is a box which i believe goes to the AC which has a filter in it and that i think dust accumulation or getting that filter wet can make the AC smell. it's mounted on top of the battery, and unhooking 3 simple clips will take it off. maybe try cleaning this to see if it works
Old Nov 8, 2004 | 06:15 PM
psk145's Avatar
2006 E55
thanks, I'll give it a shot!!
Old Nov 11, 2004 | 11:44 AM
Marktini's Avatar
Not knowing exactly where the smell comes from it's hard to say, however there was a M-B tech bulletin in September of 03
P-62_00-06 SEP 03 Body - Water Leaks Into Front Footwells
Web site: http://www.alldata.com/TSB/35/0335BNAJ.html
it's probably worth a call to your dealer, good luck
Old Nov 11, 2004 | 04:24 PM
VancouverC32's Avatar
C32
I am getting this smell now as well. It almost smells like bad B.O. I stuck my nose into the leather and smelled around but the odor is not there unless the car is running. I have to have the roof open. It appears that it is better with the recirculation button activated though. Anybody else getting this? We are into our fall wet rainy season, but today was sunny.
Old Nov 11, 2004 | 05:06 PM
redduc's Avatar
06 SLK 55, 06 S4 avant, 05 Jetta GLI, 04 Boxster S
Mine started to stink about two months ago. The dealer cleaned the A/C filter and sprayed some goodsmellingstuff through the vents. The problem still exist, but to a lesser extent. I image replacing the filter will solve the problem.
Old Nov 11, 2004 | 08:09 PM
FormerC32Owner's Avatar
2007 MB E550 Sport
Yup. The dealership ended up replacing the my whole HVAC system. Bad smells coming from the vents. What I found interesting is that there was no residual water draining from under the parked car after the AC was used heavily - like on other cars I've owned. Mercedes service thought that was weird too. So that condensation was building up somewhere.
Unfortunately, after 2 months after the full replacement, the bad moldy smells from the vents returned - especially at startup. My service advisor was very frustrated - as was I.
Old Nov 13, 2004 | 04:53 PM
chitownc32's Avatar
BLACK 2005 SLK55 AMG,02 SILVER C32(SOLD),02 ML320 SILVER(Sold),99 S320 BLUE, 03 E500 Sport Pewter
does it comes from the front passenger side ?
