More Strange audio problems
Old Nov 22, 2004 | 04:20 AM
Psychoburn's Avatar
2005 White C55
Has any c55 owners have static when they turn on their radio/cd/cd changer right when they start their car? I get htis sometimes, and in order to fix it, i ahve to completely shut down the car, take out the key, and turn it on. Sometimes it takes a few tries.. just wondering if anyone else had this problem?
Old Nov 22, 2004 | 09:05 AM
lojab's Avatar
2005 C55
Yes, I had this problem. The static was blaring at full volume on mine when this happened intermittently. The dealer advised it was a software problem and downloaded new software. Apparently MB is aware of the problem. Its been a month with no further problems.
Old Nov 22, 2004 | 10:16 AM
MerlinMc's Avatar
2005 C55
I had the exact same problem (static at full volume when I started the car) one time. It has not happened since.
The rear speaker(s) still rattle when the radio (but not the CD) is at moderately high volumes.
Old Nov 22, 2004 | 11:06 AM
MiamiAMG's Avatar
C63
That happened to me a few times in my C32, but it has yet to happen in my C55 (knock on wood). I would always fix the problem by doing the exact same thing you just described.
Old Nov 22, 2004 | 05:38 PM
Darba's Avatar
BMW E60 M5 / C55 AMG
Yep, happened to me once before... hopefully wont happen again
Old Nov 22, 2004 | 05:48 PM
Psychoburn's Avatar
2005 White C55
Yea, my rear speaker rattles too, especially if the bass is high, which i guess would make sense.. but boderately high it still bounces, i have to pretty much mute the bass...
MORE PROBLEMS:
Car won't start when i turn the key.. solution: take out key, try again
Driver side top left of window doesn't seem to stick, can hear the air coming in
Turning the steering wheel completely right and then reversing while straightening the car makes a real nasty noise
whee... the glory of having a new car
Old Nov 23, 2004 | 12:25 AM
more151please's Avatar
2007 E550, 2011 BMW 335i
yeah the static thing happened to me, pretty much like the 3 day of ownership, has happened twice since, i did the upgrade that you guys are talking about, and since has solved the problem. Although, i still get the issue of no sound when starting the car periodically, when the stereo still reads "on." The last things that happens is the "acquiring" with SAT. I guess it's good that car runs well, and it's just audio problems...
Old Nov 23, 2004 | 11:15 AM
EKaru's Avatar
Porsche
Does it make a sound like a Boeing 747 applying the brakes while taxiing? If so then the same things happens to me...
Eric...
Old Nov 23, 2004 | 02:33 PM
Psychoburn's Avatar
2005 White C55
Eric...
Yea it's really loud, and it only happens one way
Old Nov 24, 2004 | 12:42 AM
djx18's Avatar
NA
Yup
Yup it happened to me and i thought it wasn’t going to go away. I came back to my car like 5 hours later started it and it cleared up. It was on the radio, CD player and Aux port. I’m guessing software issue or maybe even hardware. It only happened once.
Old Nov 24, 2004 | 06:49 PM
cldriver's Avatar
AW '05 C55
Does the dealer have a fix for the rear speaker rattling?
Its the grill that is rattling actually.
